JUSTBOOM REMOTE IR Remote Control for JustBoom DAC / Amp / Digi
This infrared remote control will allow you to remotely control your JustBoom audio system. The latter is lightweight, compact and allows the brand's modules (Amp, DAC, Digi...) to be used up to a distance of 10m.
Reference : 13676
17,90 €tax incl.
14,92 € tax excl.
JustBoom Remote
Télécommande IR pour JustBoom DAC / Amp / Digi
JustBoom Remote Télécommande IR pour JustBoom DAC / Amp / Digi
This infrared remote control will allow you to remotely control your JustBoom audio system. The latter is lightweight, compact and allows the brand's modules (Amp, DAC, Digi...) to be used up to a distance of 10m. All the essential buttons for controlling your system and reading your files are available. In addition, the appearance of the remote control has been designed to perfectly match the brand's housings.
The JustBoom HAT and pHAT modules are delivered with an IR receiver. As this is optional, it is not delivered welded. It will therefore be necessary to solder this IR receiver to your module in order to use this remote control.
This remote control can also work with a Raspberry Pi if it is equipped with an IR receiver.
Product typeIR Remote Control
CompatibilityJustBoom (DAC, Amp, Digi...) modules with IR receiver or Raspberry Pi with IR receiver
Number of buttons12
LIRC CompatibilityYes
Range10m
Batteries2x AAA (included)
MaterialPlastic (brushed effect on top)
Dimensions146 x 39 x 19.6mm
InputNC
OutputIR
MaterialPlastic
Transmission / Reception protocolIR
This infrared remote control will allow you to remotely control your JustBoom audio system. The latter is lightweight, compact and allows the...
