The Monolith Liquid Platinum DAC is a compact DAC offering an exceptional sound reproduction quality with excellent measured performances. It is designed to be perfectly matched with the Liquid Platinum and THX-AAA headphone amplifiers of the brand, but also with any other HiFi headphone amplifier. The Liquid Platinum DAC combines an AKM AK4499EQ DAC, a...
Purifi's EVAL3 mono evaluation kit is designed to enable simple connection of the power supply and input/output signal to the 1ET7040SA amplifier module. The kit has been developed for evaluation purposes, but is also suitable for DIY applications.
True media center all-in-one combining 32 bit SABRE DAC, built-in amplifier and 4K video GPU. Ideal for building a simple and compact HiFi system. Great support for interfacing with a lot of other installations.
The EM5 is a complete high-end DAC/headphone amplifier station, with a wide range of different connectors, including balanced XLR and 4.4 mm. It can also be used as a DAC and preamplifier when combined with a separate power amplifier or active speakers.
Shanling's M6PRO is a DAP with dual AKM4497 and exceptional audio performance. It uses a version of Android OS specifically customized to maximize audio performance and offer great freedom to its user.
Soncoz unveils with its SGA1 a fully balanced headphone amplifier and preamplifier combo that is extremely powerful and musical. Benefiting from an intelligent and neat architecture as well as a sober and elegant design, it will delight the most demanding audiophiles and music lovers.
The Thieaudio Oracle MKII in-ear monitors were designed to provide a transparent sound reproduction, with the intent to mimic the tonal balance of professional studio monitors. It incorporates a hybrid technology, using an all-new 10mm LCP (Liquid Crystal Polymer) diaphragm dynamic driver, two Knowles Balanced Armature drivers and two Sonion electrostatic...
With the A50s, Topping offers a high quality headphone amplifier and sedentary preamplifier combo, integrating both balanced and unbalanced connections. Its optimized circuits, based on very good audio components, allow a precise, detailed and musical restitution. The A50s is also designed to be versatile, capable of adapting to the vast majority of...
Triangle offers a beautiful manual vinyl turntable with belt drive. This one has been specifically developed by the famous Pro-Ject brand and allows the playback of 33 and 45 rpm records. Its straight aluminum arm and its low vibration motor ensure a smooth and flawless playback. The arm as well as the Ortofon 0M-10E cell are pre-set for a quick and easy...
The Viablue NF-S6 AIR XLR cable has been specially designed to provide excellent performance for the transmission of analog signals. It promotes clear, natural and balanced sound.
ViaBlue™ SC-2 Silver Series loudspeaker cables have a combination of silvered braids for the high pass range and tinned braids for the pressureful rendition of the low pass. On the ends the ViaBlue™ T6s Series loudspeaker plug-in connections are plated with genuine gold. Both 4 mm2 leads of the SC-2 speaker cable consist of seven-stranded...
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback of the bass range. The cables are factory-installed ready-made with ViaBlue ™ T6s banana plugs, which have 24 carat genuine-gilded bronze contacts. Technically, all the frequency ranges are cleanly and...
Viablue SC-4 are high quality bi-amplified speaker cables. They include two OFC Copper conductors with Silver plating for excellent pure conductivity and two other tinned OFC Copper conductors for deep bass and good dynamics.
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback of the bass range. The cables are factory-installed ready-made with ViaBlue ™ T8 banana plugs, which have 24 carat genuine-gilded bronze contacts. Technically, all the frequency ranges are cleanly and...
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability.
Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
With the A-S301, Yamaha offers a versatile Class AB amplifier with both analog and digital inputs. The A-S301 is a versatile Class AB amplifier with both analog and digital inputs, and incorporates high-quality components in a circuitry optimized for musical and accurate sound reproduction.
Refurbished product - Grade AWith its S9c Pro, Aune presents a versatile, high-performance HiFi device in an elegantly designed case. The S9C PRO is a DAC/headphone amplifier that can also be used as a volume controler with active speakers. Among the 1080 components in the S9c Pro, Aune has incorporated high-end audiophile...
Refurbished product - Grade AFiiO presents with its Q7 an extremely powerful and complete portable headphone amplifier and DAC, taking advantage of a high-end design to allow you to enjoy your music at its best, both at home and on the move. Here, the brand has selected for you the best current components to achieve exceptional levels of performance.
Refurbished product - Grade AThe HIDIZS MP145 in-ear monitors are IEMs with an ultra-wide 14.5mm planar magnetic driver. They feature an audiophile design with no less than 7+7 N52H magnets. In terms of measurement, their high sensitivity of 104dB and low impedance of 30 Ohm enable them to be easily driven by a wide range of devices, such as your...
Refurbished product - Grade AThe Element M completes Matrix's Element range, which is the basis for the design of the other models. For this version, Matrix sought to balance performance, features and price to provide a mid-range stereo audio system for active speaker or headphone users.
Refurbished product - Grade AOctavio unveils the AMP, a compact, high-performance amplifier with advanced network connectivity that allows you to enjoy your music wherever it is stored. The Octavio is a versatile device that will adapt to all situations and needs, while offering an accurate and musical sound reproduction.
Refurbished product - Grade AWith the Shanling H2, the Shanling brand unveils a compact, versatile device that performs the functions of portable DAC and headphone amplifier with integrated player. It features high-quality components such as a Cirrus Logic CS43198 DAC chip, a second-generation XMOS XU-216 USB interface, an Ingenic X1000 processor and...
Refurbished product - Grade AThis leatherette protective cover has been specially designed to effectively protect the Shanling DAC H2, while allowing convenient access to all of the device's controls. The interior of the case is reinforced with a metal frame for added durability.
Refurbished product - Grade AWith this new product XDUOO pushes the performance of their portable DACs for better reduction of harmonic distortions, noise and better SNR. Particularly compact to accompany you in all your movements, the xDuoo Link2 BAL MAX also offers very beautiful sound performances, thanks to a carefully balanced architecture and...
Refurbished product - Grade BVersatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best possible way. Combining comfortable power, a powerful DAC, complete WiFi and Bluetooth connectivity and precise volume control, this amplifier is a must-have...
Refurbished product - Grade BThis integrated amplifier is inspired by PASS circuits and operates two high power MOSFET IRFP240 / IRFP9240. Its power stage offers massive power and detailed sound reproduction. Low frequencies are deep and emphasize the soundstage. Ideal for bringing thick and precise sound to a large room.
Refurbished product - Grade BThe Dayton Audio SD270A-88 is one of the best subwoofers available today in this price range. The brand's DVC range has been designed to offer the best possible value for money.
Refurbished product - Grade BThe Zen Can by Ifi Audio is a headphone amplifier working in pure class A. Fully dedicated to this olny function, it has a fully analog headphone amplification circuit and is connected to your sources via 4.4mm jack connector (balanced), 3.5 jack mm and RCA (single-ended).
