Refurbished product - Grade BThe new DAP Shanling M5 Ultra is equipped with cutting-edge components and a new look, making it an original device. It features the AKM AK4499EX + AK4191EQ chip combo, as well as a USB XMOS XU316 interface, enabling it to support high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512.
Refurbished product - Grade BSMSL presents with its D400Pro a DAC as versatile as it is powerful, benefiting from rigorous design and top-quality components. It is based on two AKM digital/analog conversion chips: an AK4191 and an AK4499EX. As a result, it delivers transparent, precise sound reproduction.
Refurbished product - Grade BMost electrostatic headphones offer excellent musical potential, but their performance is often limited by the associated headphone amplifier. The Topping EHA5 electrostatic headphone amplifier helps your headphones to reach their full potential, with detailed and dynamic sound reproduction.
Refurbished product - Grade SThe 1877Phono XLR cable is a major advance in the design of analog cables. Taking all the mechanical, electrical and magnetic criteria influencing the final result, the Silver Dart Zavfino series offers the best components of the Graphene, with OCC copper and silver strands adjusted with the greatest precision for a natural...
Refurbished product - Grade SHere is the OCC Silver Dart power cable by 1877Phono, having OCC Crystal Copper conductors of 3x5.26mm². The latter is the culmination of 3 years of development and testing using their proprietary "H-Wound™.
Refurbished product - Grade SThis stable, robust 6N3 / 2C51 tube will add warm tones to your sound once it has been integrated into the amplification stage of your HiFi equipment. It is made up of 9 poles and will therefore fit easily into a Noval support (9pin). It can replace tubes such as the 5670, 6H3, 6H3N or 396A.
Refurbished product - Grade SThe ETI Link Spade offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good conductivity level (IACS 95) and a perfect resistance to oxidation. The body of the connectors is made of aluminum, both robust and protecting the signal from...
Refurbished product - Grade S2.65m long pre-cut cableThis premium limited edition Furutech FP-S55N power cable has been designed with the utmost care and the best components and techniques to allow your audio system to deliver its full potential and your music to express itself in the most beautiful way. As the AC power supply is the starting...
Refurbished product - Grade SThis high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound quality of a HiFi system. The C18 is equipped with an ultra-low noise oscillator.
Refurbished product - Grade SThe AP80 Pro-X from Hidizs is a compact and powerful digital music player, benefiting from both a neat design and quality components. Behind a 2.45" IPS touch screen are two ESS ES9219C DACs, a powerful FPGA, a Bluetooth chip and a large battery. The AP80 Pro-X is as versatile as it is efficient in terms of sound reproduction.
Refurbished product - Grade SThis high frequency toroidal transformer has a double primary winding of 50V 1-100kHz. Its secondary windings deliver 2x 500V 2A for a power of 2000VA.
Refurbished product - Grade SIan Canada's ReceiverPi DDC is a compact, functional digital interface for integration into a Raspberry Pi-based network streamer, DDC or DAC project. It's a practical way of extending your project's digital connectivity. The module integrates numerous inputs: USB, coaxial SPDIF, Toslink optical and I2S via...
Refurbished product - Grade SiBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS ES9038Pro chip, supporting high resolution audio streams, up to PCM 32bit 768kHz, DSD512 and MQA 16x, while ensuring an impressively clear and rich...
Refurbished product - Grade SThe miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device is a 2x8-channel, multi-channel DSP processor featuring an HDMI ARC/eARC input. The miniDSP Flex HT features a complete suite of audio processing functions: bass management, parametric equalizers,...
Refurbished product - Grade SThis 15 pins interconnecting ribbon cable with a length of 25cm is ideal for DIY projects, allowing a quick and easy assembly. It is perfectly adapted to connect different modules together.
Refurbished product - Grade SThe Shanling EC3 is a CD player that stands out at first glance thanks to its compact size with measurements of only 188mm wide by 255mm deep and 68mm high. A certain compactness and yet incredible performances thanks to an intelligent and particularly careful design. Thanks to its know-how, Shanling offers a player that will...
Refurbished product - Grade SThe new DAP Shanling M5 Ultra is equipped with cutting-edge components and a new look, making it an original device. It features the AKM AK4499EX + AK4191EQ chip combo, as well as a USB XMOS XU316 interface, enabling it to support high-resolution PCM 32bit 768kHz and native DSD streams up to DSD512.
Refurbished product - Grade SThe 6L6WXT+ power tube is based on the vintage RCA 6L6GC design. However, it features larger plate dimensions and an improved grille structure for better power handling. It also features mica spacers with metal springs to eliminate noise and microphony.
Refurbished product - Grade STHIEAUDIO Hype 10 (HYPE for Hybrid Performance) are a pair of high-end in-ear monitors from the brand's Hype series. These earphones use 10 Balanced Armature drivers for treble, midrange and bass, as well as IMPACT² technology consisting of 2 x 10mm diaphragms for infrabass.
Refurbished product - Grade SThe Topping Hane in-ear monitors from the Arpegear series are dynamic IEMs equipped with a Ø10mm DLC (Diamond-like Carbon) diaphragm. True to its reputation, Topping offers here a product with remarkable performance, such as a THD of less than 0.05% (@ 90dB SPL), and a frequency response curve guaranteeing sound...
Refurbished product - Grade SThis high quality toroidal transformer delivers a power of 750VA with three secondary windings of 9V 27.7A each. The primary winding has a voltage of 380V 50HZ.
Refurbished product - Grade SParticularly compact to accompany you in all your movements, the xDuoo Link2 BAL also offers very beautiful sound performances, thanks to a carefully balanced architecture and quality components. It will allow you to enjoy a rich and precise sound during your headphone listening.
