Busch-Jaeger 20 EUC-81 Black Schuko outlet 16A IP20
Reference : 9972
12,90 €tax incl.
10,75 € tax excl.
These high-quality Schuko wall outlets can be used for all mounting on mains, wall and panel distributors.
They are compatible with 2-pin male plugs and double "friction" earthing contacts.
You can associate them with the various colorful frames dedicated for a more elegant effect.
Characteristics :
  • Base Type: 20 EUC-81
  • Material: plastic / metal
  • Grounding: yes
  • Protection class: IP20
  • 250V 16A
  • Color: anthracite polished
  • Fixation by rotation
  • Dimensions of the base: 63x63mm
  • Mounting Size: 71x71mm
  • External Depth: 44mm
  • Weight: 70g
Max cable diameter (mm)N/A
Mounting typeN/A
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
