VIBORG VE01R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A
The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Rhodium.
Reference : 14734
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 09-09-2025.
Viborg VE01R
Schuko Plug Pure Copper Silver / Rhodium Plated 250VAC 16A
Viborg VE01R Embase Schuko Cuivre Pur Plaqué Argent / Rhodium 250VAC 16A
The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Rhodium. This maximizes the conductivity of the connector, while ensuring excellent resistance to oxidation for maximum durability. The connector body is made of Nylon with Fiberglass. The assembly is extremely simple thanks to a screw-on system, without the need for soldering. The base accepts cables up to 5mm diameter.
Product typeSchuko plug
Connector typeFemale schuko
2 Poles + Ground
Voltage / Current250VAC / 16A
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Rhodium
InsulationNylon with fiberglass
Max. cable diameterØ5mm
ConnectionTo screw (Hex screws)
Mounting holes spacing38mm
Total dimensions51 x 51 x 38mm
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Rated current (A)16.0
2 reviews
A valider
Le produit est propre et efficace mais, les orifices semblent assez serrés, mon cable REAL CABLE ne rentr pas
This review has been posted for VIBORG VE01R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A
Excellent !
Belle fabrication, et de vraies vis, et peut accueillir des câbles de 6 mm. Indispensable.
The Schuko Viborg VE01R uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and...
