Audio-GD NFB-6 - Amplifier RCA / XLR / ACSS balanced headphones
Reference : 6496
489,00 €tax incl.
407,50 € tax excl.
This new headphone amplifier is based on the design of its big brother of the series "Master" flagship of the mark.
This one because of its extensive connectivity, particularly surprising for a product of this range is compatible with all the analog sources and amplifiers of power of the market.
Its volume management is based on a high-precision digital control with relay of the faults inherent to the potentiometers.
NFB is the acronym for Non-feedback, a technology used by Audio-Gd so that it does not "color" the sound at the level of the output stage electronics, giving you a sound of professional neutrality.
The 100% discreet design of this amplifier is backed by a high power class A power supply.
The 24k Gold Plated RCAs and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Signal / noise ratio
> 120db
Gain
0DB on Low gain, + 9DB on High gain
Output Level
Headphone output: 10V RMS
Variable output: 10V RMS
Fixed output: 2.5V RMS
Preamplifier output power
10V @ RCA
20V @ XLR
4MA @ ACSS
Output Power (Headphones) .
4500 MW / 50 ohm
3000 MW / 100 ohm
1200 MW / 300 ohm
600 MW / 600 ohm
Output Impedance
1 ohm @ XLR
Frequency Response
20Hz - 20KHz (<0.15DB)
1Hz - 170KHz (- 3DB)
Consumption
21W
Dimensions240mm X 360mm X 80mm
Weight
5KG
AccessoriesPower cord
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_1.jpg
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_2.jpg
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_3.jpg
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_4.jpg
https://www.audiophonics.fr/images2/6496/6496_AUDIOGDNFB6_5.jpg
[Img-11825-left-thickbox_default]
Excellent quality headphone amp, drives Audeze LCD2's with no problem. A1 service from Audiophonics. Thank you.
This review has been posted for Audio-GD NFB-6 - Amplifier RCA / XLR / ACSS balanced headphones
