Amplifier / Speaker Protection Module 220V 30A
This protection module for amplifiers and loudspeakers includes 2 relays with a nominal voltage of 12V DC, a resistance of 155 Ohm, a power of 0.93W and a switching current of 30A. The module is therefore perfectly suited for a powerful amplifier.
4.7 / 5
Reference : 13597
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 13-06-2025.
protection Board
Module de Protection Amplificateur / Haut-Parleur 220V 30A
This protection module for amplifiers and loudspeakers includes 2 relays with a nominal voltage of 12V DC, a resistance of 155 Ohm, a power of 0.93W and a switching current of 30A. The module is therefore perfectly suited for a powerful amplifier. DC protection from +/- 2V and a 2-second switch-on delay are also integrated. In addition, this protection card does not require the addition of a transformer, it can be directly supplied with 110-220V AC.
Product typeAmplifier / Speaker protection module
Minimal relay voltage12V DC
Relay coil resistance155 Ohm
Relay colil power0.93W
Max rela cirvuit output30V DC, 250V AC
Switching current30A
DC protectionfrom +/-2V
Ignition delay2 seconds
Dimensions (L x l x H)78.5 x 62 x 2.5mm
Weight96g
Fixation holes spacing70 x 54mm
Package1x Protection board
2x Female disconnect connector
3 reviews
Ce module de protection HP fonctionne a merveille , installer sur un ampli de puissance QUAD 520 plus aucun ploc a l'allumage et a l'extinction mais les borniers de connexions sont un peu a l'étroit pour le (GND) sinon ça vaut largement son prix espérons qu'il dureras dans le temps
This review has been posted for Amplifier / Speaker Protection Module 220V 30A
OK, but ...
Seems well put together. It seems to work. Little description on the functions.
However, the terminals are very small and only one GND. I had to attach bigger terminals to accomodate my speaker cable.
fait très bien le travail
Acheté pour résoudre un problème de ploc dans mes enceintes lors de l'extinction de mon ampli. Le colis contient des cosses pour le 220v et les vis de fixation. C'est agréable d'avoir tout de fourni avec. L'appareil en lui-même fait très bien ce pour quoi il a été conçu.
This protection module for amplifiers and loudspeakers includes 2 relays with a nominal voltage of 12V DC, a resistance of 155 Ohm, a power of...
