DOUK AUDIO D5 Audio Selector Switch 1x RCA + 3.5mm Jack / 3x RCA + 3.5mm Jack with 5-Band Equalizer
New
The Douk Audio D5 is a multifunction audio selector switch combining source selector, audio distributor, 5-band stereo equalizer, headphone amplifier, and analog VU meter in a compact and robust format. Designed to simplify the management of multiple audio devices, it can operate either in 4-IN-1-OUT mode to select one of four connected audio sources, or in 1-IN-4-OUT mode to distribute a signal simultaneously to multiple amplifiers, active speakers, or audio systems.
Reference : 21944
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 25-06-2026.
Douk Audio D5 Audio Selector Switch 1xRCA + 3.5mm Jack / 3x RCA + 3.5mm Jack with 5-Band Equalizer
DOUK AUDIO D5
The Douk Audio D5 is a multifunction audio selector switch combining source selector, audio distributor, 5-band stereo equalizer, headphone amplifier, and analog VU meter in a compact and robust format. Designed to simplify the management of multiple audio devices, it can operate either in 4-IN-1-OUT mode to select one of four connected audio sources, or in 1-IN-4-OUT mode to distribute a signal simultaneously to multiple amplifiers, active speakers, or audio systems. Compatible with desktop and home HiFi setups, it features one side with RCA + 3.5mm jack connectivity (priority input) and another side with three RCA + 3.5mm jack connections.
The D5 also integrates a 5-band analog equalizer allowing precise frequency adjustment at 80Hz, 330Hz, 1kHz, 3.3kHz, and 10kHz with a ±10dB adjustment range, as well as an EQ Bypass mode allowing the correction circuits to be completely bypassed in order to preserve a pure and unmodified audio signal. Its integrated headphone stage can drive headphones with an impedance between 32Ω and 200Ω, with an output power of 150mW at 32Ω, providing detailed and dynamic personal listening.
The D5 also stands out thanks to its large backlit analog VU meter, whose brightness can be adjusted across 6 levels, with adjustable needle movement amplitude to adapt the display according to the signal level. Thanks to its 50KΩ input impedance, 10Ω output impedance, and frequency response from 20Hz to 20kHz, it ensures excellent compatibility with the majority of audio equipment. Powered by DC 5V / ≥2A, the D5 benefits from a compact and robust metal chassis measuring 130 x 80 x 104 mm and weighing 685g, offering an elegant and versatile solution to optimize and centralize the management of an audio system.
DOUK AUDIO D5
Douk Audio D5: 5-band analog equalizer with bypass mode
The D5 integrates a true 5-band stereo equalizer allowing precise adjustment of the system's sound signature.
The adjustable frequencies are:
  • 80Hz
  • 330Hz
  • 1kHz
  • 3.3kHz
  • 10kHz
Each band benefits from a ±10dB adjustment range to easily adapt the sound rendering according to the speakers, headphones, or listening preferences.
The EQ Bypass mode allows the equalization circuits to be completely bypassed in order to preserve a direct and uncolored audio signal.
DOUK AUDIO D5: 5-band analog equalizer with bypass mode
Overview of the Douk Audio D5
Overview of the DOUK AUDIO D5
1Mode indicator
25-band equalizer controls
3VU meters
4Power / Backlight
5Volume control
6GND switch
73.5mm Jack I/O (Priority)
84x RCA I/O
93.5mm Jack I/O
10VU meter sensitivity adjustment
11USB-C power port (5V 2A)
Technical specifications
Product typeAudio Selector Switch
5-band Equalizer
ConnectivityI/O #1: 1x RCA + priority 3.5mm jack
I/O #2: 3x RCA + 3.5mm jack
Operating mode1-IN-4-OUT / 4-IN-1-OUT
Equalization frequencies80Hz/330Hz/1KHz/3.3KHz/10KHz
EQ adjustment range±10dB
EQ Bypass
Input impedance50KΩ
Output impedance10Ω
Frequency response20Hz-20KHz
Recommended headphone impedance32-200Ω
Headphone output power150mW@32Ω
VU meter backlight adjustment6 levels
Power supply5V DC / ≥2A via USB-C
Dimensions130x80x104mm
Weight685g
Package contents1x Douk Audio D5
1x 5V DC power adapter
1x USB-A to USB-C jack cable
InputJack 3.5mm
OutputJack 3.5mm
The Douk Audio D5 is a multifunction audio selector switch combining source selector, audio distributor, 5-band stereo equalizer, headphone...
