Source Selector RCA 4 to 1 / reversible PTFE Wiring
4.8 / 5
Reference : 13229
89,00 €tax incl.
74,17 € tax excl.
Source selector 4 RCA input
source selector RCA port on 4 inputs
This device can connect multiple analog sources to your preamplifier, your integrated amplifier or your passive speakers.
Its function is to allow a permanent connection between multiple sources (up to 4) to a single amplifying device.
Once the source selector has been integrated in a complex audio system, just use the knob to select the active source.
In addition to the comfort of being able to change source without repluging connections, this type of device is particularly useful for increasing the life of the mechanical parts of the installation (connectors, plugs, cables), since these will be less prone to frequent handling.
Rotative knob
The selection of the active source is done simply by turning the knob until the target position..
This knob is a mechanical switch mounted on PCBs for switching the signal.
Each position can be recognized by easy-to-read labels "A" and "B" and "C". This marking is also transposed to the case back to indentiffier easily which port corresponds to which position on the selector button.
All inputs and outputs have the same specifications. So there is not a preferred source type to RCA pair.
This type of completely passive assembly is valued for its very low coloration of the sound, as long as correct cables of moderate length are used.
source selector knob
both ways source selector
Reversible RCA Connectors
The device offers four stereo RCA inputs with the possibility to connect as many analog input sources.
For added strength, each RCA connector is mounted on its own PCB.
A single thick copper rod acts as ground.
The connector is reversible, that is to say, we can reverse the inputs and outputs to achieve a completely different setup. This system allows for example to set up a test bench where a single source will come out consecutively on multiple amplifier / preamplifier / different speakers in order to finely compare the strengths and weaknesses of each item.
Housing 100% aluminum
In order to ensure good mechanical strength and to isolate the cables, connectors and welds any electromagnetic emission capable of Engendering interference and interfering with the signal, the apparatus is protected by a housing 100% aluminum.
Selector RCA source reversible Audiophonics
Selector RCA Teflon cables
Wiring with PTFE sheath
Each wire has a PTFE sheath, providing excellent chemical inertness and resistance against all the usual factors of audio degradation: corrosion, heat, moisture.
Thanks to this protection, the device will last longer without altering the sound quality.
TypeSource Selector
PortsRCA
InputsStereo RCA X4 (Reversible)
OutputsStereo RCA X1 (Reversible)
Power supplypassive
mode selectionknob
ColorBody - Black
Front - Silver
Housing100% aluminum
Dimensions212 x 190 x 52mm
Weight1130g
ColorSilver
5 reviews
Good input switch box
I was pleasantly surprised by the quality of this switch box. When introducing a switch and extra connections into your system, there is a natural concern that this could introduce some sonic degradation. This switch box seems not to have introduced any detectable sonic degradation at all. The switch itself is very smooth and easy to turn (almost too easy) which gives an impression of good quality. I was concerned that it might be too stiff.
This review has been posted for Source Selector RCA 4 to 1 / reversible PTFE Wiring
Great Unit
Good build quality. All metal with rubber feet. Even the selector knob is metal. I think though the ABCD letters above the selector should be more clear. Perhaps in red? The unit was well protected in the shipping box. Recommended!
Presque top!
Beau produit, de qualité, pour chipoter une meilleure finition du bouton sélecteur, les arrêtes notamment.
J'ai testé 4 sources actives en même temps dont une phono, souvent problématique, et aucune interférence. En revanche, me concernant, un ploc dans les enceintes en cas de changement de sources actives.
Does The Job
Has a nice finish, similar to other silver stereo components I own so fits in well. The footprint is larger than I would like, given that all the box is meant to do is select between 4 different inputs and nothing more -- no other electronics on board. But it does serve a purpose, acting as a counterweight to 5 pairs of cable tugging at its back, allowing it to stay in place. Personally, I would have preferred something smaller but with the same weight. The walls and faceplate are already fairly thick (5 mm), so additional weight might be achieved by adding a thicker bottom. The selector switch itself is nice looking, but I would have liked more distinct increments; the switch has rather soft settings instead of stiffer click-stops. Having said all that, I don't regret purchasing this item. It's doing what it's supposed to. My streamer/amp only has one RCA input and I have several components that need to share that input. The selector looks good with the rest of the equipment, is holding its own against all of the cables that are being routed through it, and I've grown accustomed to the soft switching.
Impeccable
Très beau produit, très bien fini. Rempli parfaitement sa fonction.
Livré rapidement, merci Audiophonics. Détail : je note seulement que son prix a baissé de 8 euro 15 jours après ma commande.
