DAVIS ACOUSTICS MIA 20 Bookshelf Speakers 2 Way 80W 88dB 55Hz-20kHz Wood (Pair)
DAVIS ACOUSTICS MIA 20 Bookshelf Speakers 2 Way 80W 88dB 55Hz-20kHz Wood (Pair) New
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation.
Reference : 14779
99,17 €tax excl.
Including 0,04 € for green tax
Shipping date: 29-09-2020.
Orders placed before 11AM (GMT+1) will be shipped the same day (working day).
Davis Acoustics MIA 20
Enceintes Bibliothèques 2 Voies 80W 88dB 55Hz-20kHz (La paire)
Davis Acoustics MIA 20 Enceintes Bibliothèques 2 Voies 80W 88dB 55Hz-20kHz (La paire)
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation, as well as a soft dome tweeter made of 25mm coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
Davis Acoustics MIA 20 review by On-Mag
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
Test des Davis Acoustics MIA 20 par On-Mag
Product typeSpeakers
Speaker typeBookshelf speaker
PowerNominal : 80W RMS
Max : 110W
Number of way2
Number of speakers2
Sensitivity88dB
Bandwidth55Hz - 20kHz
Tweeter25mm, soft dome
Medium / Woofer13cm, fiberglass
ImpedanceMin. 5Ω
Cutoff frequency3000Hz
Bass ReflexFront laminar vent
Binding post typeScrew bind post. Banana plugs compatible.
Dimensions (LxHxP)16.5 x 27 x 20cm
Weight / speaker3.1kg
Finition and colorDark wood
QuantitySold per pair (2 speaker)
ColorBrown
Loudspeaker diameter (cm)130
Loudspeaker diameter (cm)25
Diaphragm typeFabric
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)88
FinishWood
Lowest frequency55
Highest frequency20000
Colissimo - TNT - SoColissimo
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small...
