ARYLIC UP2STREAM PRO V3 Receiver WiFi 2.4G Bluetooth 5.0 to I2S SPDIF Multiroom 24bit 192kHz
The Arylic Up2Stream Pro V3 is a module that acts as both a WiFi and Bluetooth receiver. Particularly practical, it will allow you to simply broadcast your music remotely from a smartphone, a computer, a NAS or many streaming services and to set up a real multiroom system. Supporting a wide variety of transmission protocols, such as DLNA, UPnP, AirPlay and Spotify Connect, it will adapt to most needs to offer great flexibility to your existing audio system.
4.0 / 5
Reference : 14658
52,90 €tax incl.
44,08 € tax excl.
Shipping date: 08-07-2025.
Arylic Up2Stream Pro V3 Récepteur WiFi 2.4G Bluetooth 5.0 vers I2S SPDIF Multiroom 24bit 192kHz
The Arylic Up2Stream Pro V3 is a module that acts as both a WiFi and Bluetooth receiver. Particularly practical, it will allow you to simply broadcast your music remotely from a smartphone, a computer, a NAS or many streaming services and to set up a real multiroom system. Supporting a wide variety of transmission protocols, such as DLNA, UPnP, AirPlay and Spotify Connect, it will adapt to most needs to offer great flexibility to your existing audio system. The module also features a full range of connectivity including I2S and SPDIF output, GPIO port, 3.5mm line in/out, USB-A and expansion ports.
What's new in the V3 version
In this version V3, the Up2Stream Pro is equipped with additional features and optimizations:
  • The Up2Stream Pro V3 can now connect to a computer and function as a USB DAC.
  • It is possible to change the Bluetooth and WiFi ID via the 4 Stream application.
  • External expansion ports have been added: SPDIF output, ADC Key expansion for controls and standard expansion port.
Arylic Up2Stream Pro V3 Récepteur WiFi 2.4G Bluetooth 5.0 vers I2S SPDIF Multiroom 24bit 192kHz Arylic Up2Stream Pro V3 Récepteur WiFi 2.4G Bluetooth 5.0 vers I2S SPDIF Multiroom 24bit 192kHz
Up2Stream Mini V3 & Up2Stream Pro V3 Comparative
Comparatif Up2Stream Mini V3 & Up2Stream Pro V3
Up2Stream Pro V3
Up2Stream Mini V3
WiFi
IEEE 802.11 b/g/n 2.4G
Bluetooth
5.0
5.0
LAN
Yes
No
USB Storage
Yes
No
Line input
Jack 3.5mm, 4 pins connector
No
3D Surround Sound
Supported
No
Android & iOS App
Arylic provides the 4Stream control application, available for Android and iOS smartphones. It allows total and easy control of your receiver and music playback. It is also via this interface that you will be able to manage your multi-room integration.
Application 4Stream Android
Application 4Stream iOS
Many streaming services available
The Up2Stram Pro V3 supports many music streaming services. You will be able to enjoy Spotify, Deezer, Tidal, Qobuz, Napster, Pandora, Amazon Music, iHeart Radio or Internet radios. You will also be able to play your music directly from your NAS connected to the local network or USB storage device.
Arylic support chart
Compatibilité des modules Arylic
Product typeWiFi Receiver / Bluetooth
WiFi NetworkIEEE 802.11 b/g/n 2.4G
EthernetRJ45 10/100M
Bluetooth version5.0
Bluetooth codecsSBC
AAC
Bluetooth transmission distance10m
Inputs1x USB-A (USB Host)
1x Micro USB
1x Jack 3.5mm / 4 pins connector
1x RJ45 Ethernet
WiFi
Bluetooth
Outputs1x Jack 3.5mm / 4 pins connector
I2S
SPDIF
SNR91dB
THD0.03%
Supported formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
Supported sampling ratesJusqu'à 24bit 192kHz
Streaming protocolsAirPlay, DLNA, UPnP, Spotify Connect, QPlay
Power supply5V 1A via Micro USB or 2 pins connector
Dimensions87.6 x 49.6 x 15mm
Accessories1x Arylic Up2Stream Pro V3
1x PH2.0 4 pins cable 22cm
1x WiFi Antenna 22cm
1x PH2.0 7 pins cable 22cm
1x 2 pins power cable 22cm
InputWiFi
InputJack 3.5mm
InputRJ45
OutputS/PDIF
OutputI2S
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate192kHz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsWeb radios
HD support ok, out CD quality
It works fine, it Connect a fine, I like the app, but it says that it support HD audio, and it is true but it out put only CD quality.
This review has been posted for ARYLIC UP2STREAM PRO V3 Receiver WiFi 2.4G Bluetooth 5.0 to I2S SPDIF Multiroom 24bit 192kHz
The Arylic Up2Stream Pro V3 is a module that acts as both a WiFi and Bluetooth receiver. Particularly practical, it will allow you to simply...
