Silicone Damping Ring for Tubes Ø24/18mm
This silicone tube ring dampens vibrations. It has an outer diameter of 24mm and an inner diameter of 18mm. It is compatible with 12AX7, 12AU7, 12AT7, 12BH7, ECC88, EL84, and other small-diameter tubes.
Reference : 21316
0,60 €tax incl.
0,50 € tax excl.
Shipping date: 01-12-2026.
Silicone Damping Ring for Tubes Ø24mm - Ø18mm
Silicone damping ring for vacuum tube
Silicone damping ring for tube: dimensional diagram
Technical characteristics
Product typeTube damping ring
Outer diameterØ24mm (0.9")
Inner diameterØ18mm (0.7")
MaterialSilicon
Compatibility12AX7, 12AU7, 12AT7, 12BH7, ECC88, EL84...
Maximum supported temperature240°C
Thickness~ 1.6mm
Contacts numberN/A
Tube typeN/A
efficace
Gain très audible en netteté de son . En regard du prix à essayer sans restriction .
This review has been posted for Silicone Damping Ring for Tubes Ø24/18mm
This silicone tube ring dampens vibrations. It has an outer diameter of 24mm and an inner diameter of 18mm. It is compatible with 12AX7, 12AU7,...
