TUNG-SOL 6386 Dual Triode Tube (Unit)
The Tung-Sol 6386 is a moderate-gain dual-triode tube designed for circuits that exploit the gradual cutoff characteristic of each of its sections, thereby allowing continuous gain modulation without any abrupt signal interruption. It relies on this controlled non-linear response to ensure dynamic level variation, which explains its use in variable-gain audio compressors, where it has helped shape the signal since the 1960s.
Reference : 22013
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 12-11-2026.
Tung-Sol 6386 Dual Triode Tube (Unit)
TUNG-SOL 6386 : Front view
TUNG-SOL 6386 : Pinout
Product typePower tube
Tube typeDual triode
Filament heating voltage6.3V
Filament heating current0.35A
Inter-electrode capacitances
Grid to plate1.2μμF
Input2.0μμF
Output1.1μμF
Filament to cathode2.6μμF
Control grid 1 to control grid 20.003μμF
Plate 1 to plate 20.1μμF
Maximum values
Plate voltage300V
Plate dissipation1.5W
DC cathode current18mA
Filament voltage90V
Typical characteristics
Plate voltage100V
Cathode – bias resistor200Ω
Amplification factor17
Plate resistance4250Ω
Transconductance4000μS
Plate current9.6mA
Grid voltage-16V @Gm=100mΩ
PackageSold by unit
Contacts number8
Tube typeDual Triode
The Tung-Sol 6386 is a moderate-gain dual-triode tube designed for circuits that exploit the gradual cutoff characteristic of each of its sections,...
