TUNG-SOL KT120 Power Tubes (Quad)
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver between 150 and 200W.
4.9 / 5
By buying this product you get 26 loyalty points
Reference : 13633
260,95 €tax incl.
217,46 € tax excl.
Shipping date: 01-12-2026.
3 >Month warranty
TUNG-SOL KT120 Power tubes high quality (Quad)
TUNG-SOL KT120 Tubes de Puissance Haute Qualité (Paire Appairée)
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver between 150 and 200W. When used with existing 6550 / KT88 / KT90 circuit parameters, the KT120 becomes overload proof, delivering peak power with extreme reliability and very long life. Moreover, by taking advantage of the ability of these tubes to handle high currents, it is quite possible to design a unique, powerful and stable amplifier.
The Tung-Sol brand has long been known for the high quality of its tubes but also for their incredible timbre. Manufacturing quality that lasts, even on these new models. Thus, Tung-Sol tubes reflect the best of the brand's vintage manufacturing, with unmatched sound and reliability.
These tubes are delivered by 4 and are matched by the brand in order to obtain the closest values and therefore the best possible performance. Ideal for perfect assembly.
Tung-Sol KT120 Tubes de puissance haute qualité (paire Appairée)
Direct interelectrode capacitances (Without shield)
Input29pf
Output10pf
Grid 1 to plate1.8pf
Heater characteristics and ratings
Average characteristics6.3V 1.7-1.95A
Maximum voltage heater of negative cathode300V
Maximum voltage heater of positive cathode200V
Maximum ratings
Plate DC VoltageTetrode : 850V
Triode 650V
Grid 2 DC VoltagePentode connection : 650V
Triode and ultra-linear connection : 600V
Grid 1 DC Voltage-200V
Plate dissipation60W
Grid 2 dissipation8W
Cathode currentPentode connection : 250mA
Triode and ultra-linear connection : 30mA
Grid 1 circuit resistanceFixed Bias : 51000 Ohm
Self Bias : 240000 Ohm
Bulb temperature250°C
Plate voltage400V
Grid 2 voltage225V
Grid 1 voltage-14V
Plate current (range)165 - 165mA
Grid 2 currentNot more than 14mA
TransconductanceNot less than 12.2mA/V
Plate resistanceApprox 3000 Ohm
Max signal power outputNot less than 20W
Total Harmonic DistorsionNot more than 14%
Cathode to heater leakage (with +-300V heater to cathode difference)Not more than 30uA
Contacts number7
Tube typeN/A
8 reviews
Rodage KT120
J'utilise ces tube sur un Jadis DA88S et je préfère vous prévenir que le rodage est très long.
Prévoyez minimum 100 heures avant d'avoir une idée et 500 heures pour un rodage total.
Très bon tube si vous avez la patience d'attendre.
This review has been posted for TUNG-SOL KT120 Power Tubes (Quad)
Confirmation
Avis rectificatif.
Cayin cs55
Ce sont d’excellents tubes qui une fois rodé ne laissent aucun doute. Le manque de hautes fréquences ressentis au départ disparaît assez vite.
La puissance est au rendez-vous. Évidemment ça chauffe un peu mais c’est pas brulant sur les transformateurs. Rien à craindre donc.
Le gros plus que j’ai obtenu c’est en les associant avec les tubes de pré ampli Mullard qui font merveille à tous les niveaux. C’est d’une justesse incroyable.
kt 120 quad
Délai 1 semaine, peut mieux faire, mais ça va.
plus important, si la logistique lit ce message.
Puisque vous expédiez dans des cartons suffisamment larges pour mettre plein de garnissage de protection, autant mettre le produit fragile au milieu des protections. j'ai reçu le quad calé dans un coin sans protection sur 3 cotés.
c'est ballot et surtout risqué pour le produit.
Les tubes sont heureusement fonctionnels.
je rejoins un avis précédant sur la sonorité, pas top au début et qui s'améliore dès la 4éme heure.
grave bien présent mais plus propre, médium se calme et apparition d'un peu d'aigu. à suivre.
Ce qui est surprenant à ce stade c'est les détails qui apparaissent, jamais entendus avant. Je sort pourtant de GEKT 88 et 88 Z pourtant de très bon tubes fins et détaillés, mais là ça va un peu plus loin tout en gardant une tonalité "chaude".
seule réserve est justement sur la justesse des timbres
pour l'instant.
Techniquement, attention à bien vérifier que votre alim peut les supporter. Sur le cs 55 ça fonctionne bien mais ça chauffe le transfo.
il faut bien le dégager pour qu'il se ventile et même comme ça j'ai mesuré 50° sur le capot.
En tout cas, à ce stade, tout indique que c'est un très bon tube et pour la durabilité... on verra, et donc 4* pour cette raison.
Grandiose !
Service AudioPhonics impecable
Montage sur un amplificateur intégré CAYIN CS55a prévu pour les KT88/EL34
Dac CHORD Hugo-câbles modulation Vovox-câbles hp Mogami- Haut parleur DALI menuet-sub REL T-zero
En remplacement des merveilleux tubes PSVANES/Philipps EL34.
Après plusieurs mois de recherche et d’hésitations. Certains tubes auraient pu me convaincre mais leur tarif m’a stoppé net. KT66GC psvane-KT88t2 psvane-Linlai global kt88D-Shuguang 6Ca7-z indisponibles…
J’ai donc tenté le coup sur les Tung Sol KT120 sans être certain que ceux-ci soit adaptés…
Sans prise de risque on avance pas !
Ceci dit j’ai pas osé les KT150. Si AudioPhonics veux bien que je les teste, je le fait volontiers !
J’ai gardé les excellents tubes PSVANES séries S en pré-amplification. J’essaierai peut être des Mullard, sans certitude d’un bouleversement.
Le montage se fait sans difficulté. Le bias est presque correct. Les tubes sont gros ; pas sûr que ma grille de protection prenne place sans une adaptation.
Je précise que j’avais eu l’occasion d’écouter mon amplificateur avec des tubes KT88 et que je n’avais pas été convaincu car je trouvais que c’était trop proche d’une « écoute transistors »… en bref ennuyeux au possible !
À froid sans rodage. Le médium est projeté en avant avec puissance, le grave est ronflant et les hautes fréquences inexistantes. Les voix et les instruments se détachent les uns des autres.
À chaud sans rodage, le son de viens plus doux et généreux dans les timbres. Toujours pas d’aigus en vu. Le grave perds sa rondeur et commence à descendre furieusement ; en fait j’ai jamais entendu mon système descendre aussi bas et avec une telle justesse dans le rendu, c’est bien tendu et profond.
Après une vingtaine d’heures…
C’est jouissif ! D’une beauté et d’une douceur extraordinaire. Des timbres fabuleux. Les fréquences hautes sont là mais tellement naturelles et tellement intégrées dans la sonorité native des instruments. Ça file haut avec beaucoup de finesse.
Les mauvais enregistrements restent mauvais mais audibles.
Le rodage ne semble pas linéaire ; le gros du rodage se fait entre 10 et 50 heures, en suite le gain entre les 50 heures et 100 heures ne semble que de 20 à 30%.
Je remets un message à 100 heures.
Pas l’ombre d’un doute. Aucun regret !
Très bon tube
Utilisé depuis un peu plus d'un an sur des bloc mono (DIY) en push-pull, j'en suis très satisfait. Elles ont remplacé des Gold Lyons KT88 avec beaucoup de bonheur. Un son plus claire, plus aéré et un gain significatif en transparence. J'appelle "transparence" neutralité. Le matériel s'efface derrière la musique. La réserve en puissance permet de voir loin, en durée de vie, car elles encaissent mieux les montées de courant intempestive lors de la mise en route par exemple et accessoirement permettent un choix d'enceinte plus étendu ; plus de 60W par bloc dans mon cas, je peux leurs coller du HP à faible rendement sans arrière pensée.
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull...
