CANARE GS-6 High performance unbalanced OFC cable Carbon shielded Ø5.8mm
Reference : 10459
3,90 €tax incl.
3,25 € tax excl.
Cable designed and manufactured in Japan by the famous CANARE company, this very high quality asymmetrical GS-6 cable was originally dedicated to the professional broadcast market and recording studios.
Itsand the cables of the firm did not take long to penetrate the Hi-Fi market.
hehas the particularity of having high quality mechanical and electrical characteristics and is among the asymmetric cables of a great flexibility with an exceptional shielding which attenuates almost all the noises of manipulation and interferences.
Thisis primarily designed for the use of analog signals over long lengths. For the use of coaxial digital cables we recommend the following model: Câbthe digital coaxial 75 Ohm Canare LV-77S.
Features:/ Strong>
  • Solid Bare Copper conductor (1x 127 strands)
  • Cross section / diameter: 18AWG / 0.823mm² / Ø 1.02mm
  • Insulation: PE Polyethylene
  • Shielding: 92% Woven OFC copper and spiral carbon sheet
  • Sheath: PVC (thickur: 1mm)
  • Protection against EMI / RFI interference
  • Nominal capacity: 160 pF / m at 1kHz
  • Overall Cable Diameter: 5.8mm
Diameter (mm)5.8
Length (m)Sold by length
Number of conductors1
Insulation materialPE
ShieldingYes
Section (mm²)0.26
Ground / ShieldingYes
7 reviews
Un super câble made in Japan !
La réputation de ce câble n’est plus à faire, c’est un excellent rapport qualité prix, le diamètre externe reste raisonnable ce qui le rend utilisable avec beaucoup de prises différentes jack, CINCH XLR etc.
Personnellement je l’utilise principalement pour confectionner des cordons guitare et accessoirement en Hi-Fi.
Un seul regret : il n’est disponible qu’en noir.
This review has been posted for CANARE GS-6 High performance unbalanced OFC cable Carbon shielded Ø5.8mm
Tres bien
J'avais un câble bas de gamme (grand surface) et depuis, je vous confirme la différence ...
Je m’y attendais pas
J’utilisais un Réal câble eca préfabriqué qui jusqu’à présent me donnait entière satisfaction pour connecter mes sources cd/dvd.
Depuis l’acquisition d’un Streamer Atoll Ms120, et malgré une centaine d’heures de rodage, le côté sec et les duretés dans les aigus ne s’estompaient pas..
Au vu des prix pratiqués dans les câbles préfabriqués abusifs, j’ai décidé de me monter celui-ci avec des rca Amphemol.
Sans même être rodé, de suite le son est bcp plus équilibré sans cette prédominance dans les aigus, une fluidité extraordinaire, ça descend très bas même à faible volume !
Apparemment, se marie avec Atoll à la perfection !
Disappointing
Physical qualities are very good, but for high end sound quality the semi-balanced use of a symmetrical cable (shielding connected at only one end) is just better, I experienced.
Ottimo prodotto
Si tratta di un cavo di indubbia qualità.
La guaina esterna è morbida e il cavo è flessibile.
La schermatura è davvero generosa a trame molto fitte.
Il polo "caldo" beneficia di un doppio isolamento, anche le sezioni sono più che generose !!
Ottimo prodotto ad un prezzo onesto.
spedizione rapida e ottimo imballaggio
