DDHIFI TC28MAX Adapter USB-C Male to 2x USB-C Female
The TC28Max is a USB-C adapter from ddHiFi featuring a male USB-C connector and two female USB-C ports, one of which is OTG-compatible and the other dedicated to charging. This design allows you to charge your phone and power your DAC or amplifier at the same time, ensuring a constant voltage across both outputs. The adapter’s body is made from aluminium alloy and CNC-machined for a robust chassis.
Reference : 21956
29,91 €tax incl.
24,92 € tax excl.
Shipping date: 26-11-2026.
ddHiFi TC28Max Adapter USB-C Male to 2x USB-C Female OTG Gold-plated
Thumbnail of the ddHiFi TC28Max
In addition, the TC28Max supports the USB 3.1 protocol and is equipped with three sets of six-channel USB-C and PD DRP communication modules. Added to this is the integration of AOS MOS transistors, enabling support for currents of up to 10A. It uses a 4-layer printed circuit board with gold plating to ensure advanced anti-interference performance.
Product typeUSB-C adapter
Connectors1x USB-C male
1x USB-C female OTG (data)
1x USB-C female (charging)
Body materialAluminium CNC
USB-C charging60W max
Dimensions23.8x17x9.5mm
Weight7.8g
Package1x TC28Pro
ConnecticMale & Female
ConnectorUSB-C
DDHIFI TC28MAX Adapter USB-C Male to 2x USB-C Female OTG Gold Plated
The TC28Max is a USB-C adapter from ddHiFi featuring a male USB-C connector and two female USB-C ports, one of which is OTG-compatible and the...
