Male USB-C Cable USB4 40Gbit/s Silver Plated Copper Shielded 0.8m
The Lindy Anthra Line USB-C cable is the perfect choice for high-performance connections, both at home and in a professional installation. It features triple shielding with silver-plated copper conductors for seamless signal transmission. The connector contacts are gold-plated, maintaining excellent conductivity and durability.
The cable's USB4 standard supports high bandwidth of up to 40Gbit/s for fast transfer of large amounts of data. In addition, this cable is E-marked and is capable of delivering 100W 5A of power to devices using the most efficient power profiles.
| Specifications | |
| Product type | USB-C cable |
| Connectors | 2x Male USB-C |
| Length | 0.8m |
| USB Version | 4 |
| Chipset | EJ913D |
| Cable conductors material | Silver plated copper |
| Conductors section | For power supply : 23AWG For data : 30AWG / 33AWG / 34AWG |
| Shielding | Tresse de cuivre étame 85% |
| Connectors contacts material | Copper |
| Connectors contacts plating | Gold |
| Supported bandwidth | 40Gbit/s |
| Maximum resolution | 8K @ 60Hz |
| Nominal attenuation | 0.5MHz - 15GHz ≤ 11dB |
| Minimum bending radius | 28.8mm |
| Cable diameter | Ø4.8mm |
| Sheath material | TPE |
| Certifications | RoHS REACH California Proposition 65 UL |
| General | |
| Color | Cable : Black Connectors : Gray |
| Length (m) | 0.8 |
| Shielding | Yes |
| Section (mm²) | 0.0509 |
| Section (mm²) | 0.025 |
| Section (mm²) | 1.00 |
| Section (mm²) | 0.258 |
| Section (mm²) | 0.020 |
| Connector | USB-C |
| Conductors Plating (Cable) | Silver |
