OTG 5Gbps
This USB-C 3.0 male connector will allow you to design high-quality USB cables. The 3.0 standard allows data rates of up to 5Gbps. In addition, the connector is OTG compatible.
| Specifications | |
| Product type | Male USB-C connector |
| USB version | 3.0 |
| OTG | |
| Max bandwidth | 5Gbps |
| Mounting type | To solder |
| Rated voltage/current | 5V 4A |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male |
| Connector | USB-C |
| Contacts Material (Connector) | N/A |
| Contacts Plating (Connector) | Gold |
