DD TC44B Balanced Headphone Amplifier DAC Adapter Lightning Hi-Res 2x CS43131
The DD TC44B is a compact and powerful DAC and balanced headphone amplifier adapter, equipped on the one hand with a male Lightning connector and on the other hand with a 2.5mm and 4.4mm balanced jack.
4.0 / 5
Reference : 15258
89,00 €tax incl.
74,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
DD TC44B
DD TC44B Adaptateur DAC Amplificateur Casque Symétrique Lightning Hi-Res 2x CS43131
The DD TC44B is a compact and powerful DAC and balanced headphone amplifier adapter, equipped on the one hand with a male Lightning connector and on the other hand with a 2.5mm and 4.4mm balanced jack. The digital/analog conversion and amplification stages are based on a pair of CS43131 chips, allowing to support high resolution files but also to accompany demanding headphones with high impedance. All connectors are gold plated to ensure excellent transmission quality and durability.
Test du DD TC44B par Audio Science Review (Amir)
" The TC44B nails objective performance, producing desktop class performance in a tiny package. "
Product typeDAC / Headphone amplifier adapter
Connectors1x Male Lightning
1x Balanced female Jack 4.4mm
1x Balanced female Jack 2.5mm
Cable length85mm
DAC Chip2x CS43131
DSD up to DSD256
Dimensions (triangle part)18.3 x 16.8 x 30mm
Lightning connector length13.5mm
InputLightning
OutputJack 4.4mm
OutputJack 2.5mm
Contacts Plating (Connector)N/A
Epatant
Acheté plus par curiosité que par conviction afin de connecter mes IE800 (cablage symetrique ALO AUDIO) pour valider les albums écoutés sur Amazon HD depuis mon iPhone avant achat (je fais encore parti des gens qui tésaurise une disocotheque. Le DAC tient toutes ses promesse, et drive parfaitement les IE800 mais également mon HD700 (cablé ForzaAudioworks). J'enlève une étoile (je suis très très dur) parce que le morceau Deja Vu de Roger Waters pose problème
de conversion Ces le seul morceau identifié à ce jour sur plusieurs centaines écoutés.
Je recommande fortement pour profiter pleinement du format UltraHD sur iPhone avec un casque symétrique
This review has been posted for DD TC44B Balanced Headphone Amplifier DAC Adapter Lightning Hi-Res 2x CS43131
The DD TC44B is a compact and powerful DAC and balanced headphone amplifier adapter, equipped on the one hand with a male Lightning connector and...
