NEUTRIK NAC3FC-HC POWERCON Power Connector 32A Ø20mm
Reference : 6573
19,50 €tax incl.
16,25 € tax excl.
Shipping date: 09-09-2025.
This fast power supply connector locks the connector into its socket to prevent unintentional disconnection. This particularly robust connector is designed for easy assembly and use.
Features:
  • Voltage: 250V AC
  • Current: 32A
  • Ground contact
  • Max cable diameter: from 8 to 20mm
https://www.audiophonics.fr/images2/6573/6573_NEUTRIKNAC3FCHC_1.jpg
https://www.audiophonics.fr/images2/6573/6573_NEUTRIKNAC3FCHC_2.jpg
Ampères : 32 A Contact de terre Diamètre acceptable du câble : de 8 à 20 mm
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPowercon
Rated current (A)32.0
Great alternative for high end audio
I use this for my DSS mains conditioner with a Furutech cable and FI-e50 ( non-NCF) schuko on the other end. The powercon did not deteriorate the sound, it is clear, detailed but not very smooth in a high-end way. I guess this is due to the silver. But the Furutech rhodium will take care of the signal becoming smooth enough. Considering the price this powercon is a real steal.
This review has been posted for NEUTRIK NAC3FC-HC POWERCON Power Connector 32A Ø20mm
