This socket is completely dismantled and reassembled, it has high-level connectivity to enable you to make you - same very high quality cables and areas dedicated to advanced audio uses.
| Characteristics | |
| Max conductor section | 14mm² |
| max cable diameter | 12.5mm |
| Contacts | Brass-plated copper |
| electrical Specifications | 15A / 125V |
| Weight | 66g |
| Dimensions | 72 x 40mmØ (without plugs) |
| Max cable diameter (mm) | 19.0 |
| Mounting type | To screw |
| Connectic | Male |
| Connector | Type B (NEMA) |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | None |
