Petit boîtier solide,bien construit,avec façade en alu.
Fait le job.
Parfait
Merci Audiophonics de nous proposer ce type de produit de bonne qualité avec un tarif avantageux.
This controller is exclusively designed for use at the output of a source equiped with a magnetic cell (vinyl player).
Its function is to amplify the signal from your turntable before volume control and amplification.
Ideally, it will be connected to an integrated amplifier bringing volume control and power amplification altogether. Alternatively, it may be incorporated into a configuration where the preamplifier-volume controller precedes a power amplifier.
This phono preamplifier operates through a high performance,low noise two-way preamplifier NJM2068.
This component is designed for applications requiring high sensitivity processing signals in an environment requiring very low noise.
The NJM2068 has excellent specifications for a phono preamplifier application with distortion barely correlated to the device temperature variations, a wide bandwidth (27MHz), a THD of 0.001% and a slew rate of 6V / microseconds.
Working in concert with a series of well-placed capacitors in a very clean design, AOP NNJM 2068 meets all the conditions to offer a clear, accurate sound with any vinyl player.
Installation is made simple with easy access and well arranged rear panel.
Simply connect the input of the device to your vinyl player with a stereo RCA connector and connect the output to an integrated / pre-amp amplifier via the same connector type.
| Specifications | |
| Chip | NJM2068 |
| RMS level | 308mVrms |
| SNR | -75dB |
| THD | 0.01% |
| Input | Stereo RCA (phono MM) |
| Output | RCA |
| Power-Supply | DC 12V 2A (AC adapter not included) - Jack DC 5.5 / 2.5mm |
| Dimensions | 130 x 100 x 35 mm |
| Weight | 0.25kg |
| Parts supplied | |
| AUDIOPHONICS T2 | x1 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
olivier B.
