Tout est dans le titre. Qualité de fabrication , qualité sonore, silencieux même avec sa petite alimentation externe.
Possible qu'il gagnerait avec une alimentation de qualité, à voir...
![[GRADE S] IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-digital-audio-player-dap-dac-es9038po-balanced-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-black.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Discreet Headphone Amplifier 5W Bluetooth 32bit 768kHz DSD512 MQA Back](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-discreet-headphone-amplifier-5w-bluetooth-32bit-768khz-dsd512-mqa-back.jpg)
 FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071
The FX-Audio BOX02 is a low price phono preamplifier, offering a very high quality internal design. It supports the board with MM and MC cells, a switch under the device to select one of the two technologies. The preamplification stage is based on low noise OPA NJM2068 and JFET TL071C. These offer excellent audio performance in terms of noise and distortion. On the connector side, there is a stereo RCA input for MM or MC turntables and a stereo RCA output to connect the unit to your amplifier. A screw terminal block allows you to add the ground of your board.
The device also offers several settings via 3 DIP switches positioned underneath the device. The first DIP switch allows you to choose between MM and MC cells but also to select a gain level at 0dB or 6dB. The other two DIP switches, each corresponding to a channel (L/R), allow you to select a capacitance and an impedance in accordance with your phono cell. A setting that is usually found mainly on high-end phono preamplifiers.
| Specifications | |
| Product type | Phono MM/MC Preamplifier |
| Components | AOP NJM2068 AOP TL071 |
| Output level | 310mVrms |
| Input | 1x RCA phono MM/MC |
| Output | 1x Stereo RCA |
| THD | 0.8% |
| SNR | -76dB |
| Geneéral | |
| Power supply | 12V 1A via Jack 5.5/2.1mm (power adapter included) |
| Dimensions | 98 x 130 x 33mm |
| Weight | 310g |
| Color | Silver |
| Package | 1x FX-Audio BOX02 1x Power supply |
| Average votes  5.0 / 5  4 reviews | Why write products reviews ?  You can share your feelings about products and help other people by sharing your experience |
Gérard M.
Olivier C.
benjamin D.
JEAN-LOUIS B.
