Phono USB Preamplifier PDX015 Power Dynamics | USB interface
POWER DYNAMICS Préampli Phono USB PDX015
The PDX015 preamp by Power Dynamics allows you to connect a vinyl player to a computer or a laptop. A recording software is provided to convert your disk collection to digital audio files. It works as an external soundcard including RIAA sound correction.
Reference : 12618
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Power Dynamics PDX015
Préamplificateur Phono USB - Audacity
Power Dynamics PDX015 Préamplificateur Phono USB - Audacity
The PDX015 is an ideal RIAA preamplifier for all your MM sources. Thanks to the Line/Phono switch, the preamplifier allows you to digitize other audio sources via the RCA input.
The Power Dynamics PDX015 is powered directly via USB (cable included). No additional power supply is required, making it a very minimally invasive device from a cabling point of view.
Its small size (125 x 115 x 40mm) allows it to be quickly forgotten when not in use. Similarly, its reduced weight (500g) makes it a semi-nomadic accessory that you can easily take with you to your audiophile friends.
The PDX015 does not transmit audio IN to OUT, it is an acquisition card.
Audacity
The PDX015 comes with an Audacity software installation CD. This software offers the ability to digitise your discs in high definition and even make patches / fine tuning of audio files.
Power Dynamics PDX015 Préamplificateur Phono USB - Audacity"/>
Product typePhono preamplifier
Acquisition card
Input1x Stereo RCA
Output1x Stereo RCA
Grounding terminal connector
RIAA correction
USB2.0
CPUDual Core
RAM2Go
CompatibilityWindows XP, Vista, 7, 8, 10
Power supply5V via USB
Weight500g
Dimensions125 x 115 x 40mm
ColorSilver
Package1x Power Dynamics PDX015
USB-B to USB-A cable
Audacity install CD
ColorSilver
ClassN/A
Copie amélioré
Appareil compact et simple d'utilisation avec le logiciel Audacity.
Possibilité de copier tout type d'appareils y compris des CDs pratique quand on ne possède plus d'ordinateur de bureau...
Qualité du son amélioré par le système riaa permettant de redécouvrir ses vieux vinyles !
This review has been posted for POWER DYNAMICS PDX015 Phono USB Preamplifier - Audacity
The PDX015 preamp by Power Dynamics allows you to connect a vinyl player to a computer or a laptop. A recording software is provided to...
