FOSI AUDIO BOX X5 Phono Preamplifier
The Fosi Audio Box X5 phono preamplifier is a small, high-quality device that accepts MM and MC cells. Based on the use of OPA1612 in DIP8 and high-fidelity RIAA equalization, it delivers highly qualitative sound reproduction of your favorite vinyl records.
4.8 / 5
Reference : 20240
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 12-05-2026.
Fosi Audio Box X5 Phono Preamplifier MM/MC OPA1612
Photo of Fosi Audio Box X5
The Fosi Audio Box X5 phono preamplifier is a small, high-quality device that accepts MM and MC cells. Based on the use of OPA1612 in DIP8 and high-fidelity RIAA equalization, it delivers highly qualitative sound reproduction of your favorite vinyl records. It also features 4 levels of gain adjustment, enabling it to adapt to a variety of sources. Gain can be set at 66dB, 56dB, 48dB and 38dB. The Fosi Audio Box X5 is powered by 16V AC.
Example of a HiFi installation with the Fosi Audio Box X5
Fosi Audio Box X5: MM/MC compatibility and 4 gain levels
The Fosi Audio Box X5's four gain levels ensure compatibility with different sources. In addition, a switch lets you set the input impedance to 47kOhm for MM cells or 100kOhm for MC cells.
Gain can be set to the following values via a rotary switch on the rear of the unit: 66dB, 56dB, 48dB or 38dB.
Gain level and MM/MC compatibility
Fosi Audio Box X5: high-fidelity RIAA equalization
The equalization of the Box X5 ensures a level of detail and clarity in the final sound reproduction for a rich listening experience. This equalization significantly reduces noise levels and delivers a wide dynamic range.
RIAA equalization for the Fosi Audio Box X5
Fosi Audio Box X5: Dual OPA1612
The DIP8-mounted OPA1612s on the Box X5's circuit offer a high-quality audio experience, and are also easily replaceable for any user wishing to customize their listening experience.
Photo of Fosi Audio Box X5 AOP1612
Fosi Audio Box X5 overview
Overview of the Fosi Audio Box X5
1Power indicator
2Power button
3MM/MC-compatible RCA input
4Gain selector
5RCA output
6Ground terminal
716V AC power input
Fosi Audio Box X5 test by Audio Science Review
Fosi innovates by bringing best in class performance while packaging the unit in an attractive enclosure while keeping the cost very reasonable. There is nothing more to ask! I am happy to recommend Fosi Box X5 phono stage.
Product typePhono preamplifier
OPAOPA1612 DIP8 format
Input1x RCA phono input (MM/MC)
Output1x RCA output
THD≤ 0.009%
SNR≥ 92dB
Frequency response20Hz-20kHz (±0.015dB)
Gain adjustment66dB / 56dB / 48dB / 38dB
Power supply16V 1A
Dimensions104 x 165 x 356mm
Package1x Fosi Audio Box X5 phono preamplifier
1x Mains adapter
InputPhono
ClassN/A
5 reviews
surprenant!
Une petite boîte toute simple... branché à mon Micro Seiki BL91, bras SME3009 SE et un petit Denon DL110.
Directement relié à mon Ampli BGW 750G par un câble de 5m.
Première surprise: pas de souffle, pas de hum.. rien.
Premier disque: deuxième surprise. Je m'attendais pas à ça. Proche du CD. Sauf moins de grave et le haut un peux voilé. Un disque quoi.
Par contre, très dynamique. Avec mes enceintes Vulkan Mk3 ça martèle. La plage stereo... restreinte, du vinyl quoi...
Après deux semaine je gratte un 2134 du fond du tiroir et remplace le 5532.
Et ben, ça n'a pas raté ! Tout est revenus: les graves, les hauts et la plage stereo. Plus de voile. Sublime! Et pratiquement pas de différence aux CD mise à part les restrictions du vinyl.
Après 5 minutes je ne ressent plus la différence si c'est un disque ou un fichier...
Comme j'ai pus constater, il s'agit de deux 1612 en entré: un pour amplifier, un après le filtre RIAA et un 5532 en sortie. Je suppose un filtre passif.
Je conseille fortement.
This review has been posted for FOSI AUDIO BOX X5 Phono Preamplifier MM/MC OPA1612
Très bon mais...
Très bon petit appareil, silencieux, au son proche du X2 ce qui est un compliment. Il semble un peu plus doux que le X2. En MC, ce qui est la raison de mon achat, je suis un peu frustré, pas d'effet whaou. A vérifier toutefois sur plus de configurations que la mienne (chez moi, AT-OC9XEB)
Vraiment bon et bien conçu pour le prix ^^
Ce petit boitier Fosi X5 remplace avec efficacité un pré ampli phono Cambridge Azur 551P qui a un étage de pré amplification en classe A, ce X5 en version d'origine rivalise sans aucun soucis avec le 551P en plaçant le gain sur 38, si je commute le gain sur 48 j'obtiens une meilleure dynamique pour aborder mon pré ampli Lpass2 Prime (classe A) et en effet le X5 avec ce gain variable lui permet de se distinguer et d'obtenir un meilleur rendu selon la sensibilité de la cellule mais aussi de mieux s'adapter aux périphériques en aval (pré ampli et ampli de puissance), donc je trouve judicieux de la part de la marque Fosi d'avoir mis un sélecteur de gain qui rend le X5 plus flexible.
Je n'ai pas pu résister à la tentation de le faire évoluer, en remplaçant le banal opa 5532 qui est monté sur un socket dip8 et si vous êtes méticuleux je vous invite à le faire car l'opération d'ouverture du boitier reste assez simple, mais avant tout bénéfique quand on a la possibilité d'avoir en stock plusieurs types d'opa, j'ai donc testé 2 opa soit le LM49720 et le Burr Brown 2134.
Pour effectuer ce comparatif, j'ai choisi un morceau assez chargé en quantité d'instruments, et surtout avec une excellente prise de son, j'ai utilisé le logiciel Audacity avec ma carte son Roland et j'ai donc enregistré 2 fichiers audio en WAV que j'ai pu par la suite comparer en ouvrant les 2 fichiers dans un lecteur et en switchant de l'un à l'autre, puisque la commutation entre les 2 fichiers était rapide et efficace car mon comparatif a été concentré sur les 30 premières secondes du morceau qui comportait une introduction à la trompette et d'autres instruments qui venaient se greffer pour compléter la scène sonore.
J'ai exclus l'opa 5532 monté d'origine car il n'a aucun intérêt dans ce comparatif, toutefois le 5532 me servira de point de repère pour constituer une comparaison entre: 5532 VS LM49720 / 5532 VS BB2134 / et LM4972 VS BB2134.
5532 VS LM49720: le LM49720 apporte une dynamique largement supérieure au 5532, plus de matières mais le LM49720 propose à peine plus de précision et de détails car même si il est plus dynamique, le placement des instruments reste à l'identique du 5532, c'est plat et bien droit comme message sonore projeté mais çà manque de vie, en déduction le LM49720 apporte guère mieux que le 5532 hormis la dynamique et à peine plus de précision, le choix de mettre LM49720 dans le Fosi X5 ne me semble pas cohérent pour une si faible amélioration.
5532 VS BB2134: le BB2134 est sensiblement identique en dynamique au 5532, par contre il apporte tellement plus dans sa manière de détailler la musique que je ne vais pas m'étendre plus que çà car le 5532 n'est pas du tout à la hauteur pour tenter de rivaliser avec le BB2134 qui fait tellement mieux !! déjà on peut vite constater les limites du 5532 qui a mon goût est loin d'être assimilable à la catégorie de la musique haute définition, toutefois on trouve de nos jours le 5532 dans 90% des appareils d'entrée de gamme mais il bride tout simplement les performances.
LM49720 VS BB2134: le LM49720 conforte son aspect dynamique supérieur au BB2134 tout comme avec le 5532, mais c'est le seul point fort pour celui ci puisque je trouve que le LM49720 est trop brouillon en le comparant au BB2134, le morceau choisit débute avec un jeu de batterie qui passe de la gauche vers la droite puis il est suivi par la trompette avec des notes qui raisonnent avec un bel effet de sustain (maintien de la note jouée) et j'avais ce point repère grâce à la version CD qui respecte ces détails, cas de figure avec le LM49720 l'effet de stéréo de la batterie qui passe de gauche à droite est quasiment inexistant mais le pire c'est qu'il écourte la durée des notes de la trompette et là c'est la catastrophe car çà ne sonne pas naturel, pour autant le 5532 fait exactement la même chose avec une dynamique moindre.
Le BB2134 respecte la musique, en reproduisant à la perfection l'effet stéréo du jeu de la gauche vers la droite de la batterie, en maintenant la résonnance de chaque note de la trompette et surtout en respectant le timbre de la trompette qui sonne vraiment en merveille, car avec mes enceintes KLIPSCH RF5 (filtres full tweak Mundorf Suprême) une trompette qui sonne mal timbré avec les pavillons d'aigu et le haut rendement ! çà peut vite devenir difficile à écouter.
En conclusion, je suis très satisfait de ce Fosi X5 et encore plus enjoué quand je l'écoute avec le BB2134 qui apporte une belle évolution sonore, donc pour ma part je le considère comme un très bon rapport qualité surtout si on rajoute la modeste somme déboursée pour se procurer un opa BB2134, cet ensemble à faible coût n'a aucun soucis pour se distinguer de la concurrence quand on tient compte de la qualité des composants embarqués et en tenant compte aussi du sélecteur de gain qui est utile et rend le Fosi X5 adaptable dans un grand nombre de configuration possible.
Fosi audio box5
Super petit preampli phono j'ai une cellule MM ortofon 2m red, j'ai mis le réglage sr 48db, ourahh mon volume est enfin plus élevé la qualité sonore est au rendez-vous détaillé scène sonore bien pleine, bref gain également total sur la qualité sonore , preampli peut cher mais avec une grande qualité, pourquoi investir plus cher!!!!j'ai une patine Technics SL 1500C reliée à mon ampli intégré SPEC 777EX
je conseil ce petit preampli , il sonne vraiment bien grâce à ses composants de haute qualité notamment les petits condos nichicon!!!!
Best Overall
Excellent again all the transaction with the shop.
The Fosi Audio Box X5 phono preamplifier is a small, high-quality device that accepts MM and MC cells. Based on the use of OPA1612 in DIP8 and...
