Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Voltage Regulator
Pierre M.
Fonctionne
bonjour ; fonctionnement correcte , mais tassement de dynamique et quelque peu bruyant ...!
Thierry d.
éclairage vintage
Parfait pour mon ampli Scott A 436 : les Vu-mètres sont à nouveau splendides .
Remarquable avec Roon
Je l'utilise comme Endpoint sur un DAC Audio GD avec Roon sur un NUC avec RoonRock comme serveur. L'écoute est...
Voltage Regulator
  • Ref : 13304
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of ré discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18352
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18353
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14810
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18874
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13968
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14497
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16070
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 17391
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14036
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14856
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18875
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14280
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14485
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16071
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 17392
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14561
    In Stock
    This ST LM317T 3-terminal voltage regulator in TO-220 package has an input voltage range of -0.3V to 40VDC for an output voltage range of 1.2V to 37VDC and an output current of 1.5A.
    1,00 € 0,83 €Ex.
    In Stock
