Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Voltage Regulator
Zoltán K.
Very practical, good quality
This is a robust, well‑built adapter that proves genuinely useful whenever a sufficiently long power cable isn’t available. I...
Adam K.
Holo Cyan 2 - wysyłka do Polski
Na początku kilka słów o samym zakupie. DAC został bardzo szybko wysłany, był dobrze zabezpieczony i dotarł bez żadnych...
Francois P.
J'ai associé ce préampli avec l'ampli de puissance AUDIOPHONICS LPA-S450ET et j'avoue que je suis séduit par le...
Voltage Regulator
  • Ref : 14484
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,94 € 37,45 €Ex.
    In Stock
  • Ref : 14518
    The Sparkos Labs brand, which specializes in the design of high quality discrete electronic components, has created a range of discrete controllers to advantageously replace adjustable monolithic controllers. They are in the standard TO-220 format with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18351
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of ré discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13304
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18352
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18353
    Reduced price!
    In Stock
    31,43 € 26,19 €Ex.
    44,90 € In Stock
  • Ref : 14810
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18874
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13968
    Reduced price!
    In Stock
    40,41 € 33,68 €Ex.
    44,90 € In Stock
  • Ref : 14497
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16070
    Reduced price!
    In Stock
    35,92 € 29,93 €Ex.
    44,90 € In Stock
  • Ref : 17391
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14036
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14856
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18875
    Reduced price!
    In Stock
    31,43 € 26,19 €Ex.
    44,90 € In Stock
  • Ref : 14280
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14485
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16071
    Reduced price!
    In Stock
    35,92 € 29,94 €Ex.
    44,90 € In Stock
  • Ref : 17392
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14561
    In Stock
    This ST LM317T 3-terminal voltage regulator in TO-220 package has an input voltage range of -0.3V to 40VDC for an output voltage range of 1.2V to 37VDC and an output current of 1.5A.
    1,00 € 0,83 €Ex.
    In Stock
