TONEWINNER AT-600 Audio-Video Processor / Home Theater Preamplifier
The Tonewinner AT-600 is a 8K 16-channel home theater processor designed for processing immersive configurations up to 9.3.4, relying on a dual-core DSP combined with an ESS DAC to ensure precise multichannel stream management. It integrates an HDMI 2.1 interface compatible with 8K with an independent routing matrix, complemented by varied digital and analog inputs and 16-channel outputs in RCA and XLR, allowing flexible integration with multiple subwoofers.
By buying this product you get 224 loyalty points
Reference : 22123
2 249,00 €tax incl.
1 874,17 € tax excl.
Shipping date: 13-11-2026.
Tonewinner AT-600 Audio-Video Processor / Home Theater Preamplifier 8K Dolby Atmos 16 Channels 9.3.4 / 7.3.6
Thumbnail of the Tonewinner AT-600
The Tonewinner AT-600 is a 8K 16-channel home theater processor designed for processing immersive configurations up to 9.3.4, relying on a dual-core DSP combined with an ESS DAC to ensure precise multichannel stream management. It integrates an HDMI 2.1 interface compatible with 8K with an independent routing matrix, complemented by varied digital and analog inputs and 16-channel outputs in RCA and 14-channel outputs in XLR, allowing flexible integration with multiple subwoofers. The whole is completed by the integration of Dirac Live with advanced bass management, automatic calibration of distances, delays and levels, as well as a per-channel parametric equalizer, allowing precise adaptation of system behavior to the room and sources.
Tonewinner AT-600: Connectivity and audio-video signal management
The Tonewinner AT-600 integrates an HDMI 2.1 interface composed of 6 inputs and 2 outputs, including 3 inputs compatible with 8K, allowing management of streams up to 8K in YUV4:4:4 with a bandwidth of 40Gbps while ensuring compatibility with Dolby Vision, HDR10, HDR10+, HLG and 3D. This architecture integrates an audio-video matrix enabling independent routing of signals to the outputs, allowing differentiated distribution depending on usage.
The connectivity includes 2 coaxial inputs, 2 optical inputs, 3 stereo analog inputs (RCA), as well as a 5.1 multichannel analog input, allowing integration of digital and analog sources without intermediate conversion. It also includes an Ethernet port, a USB port, a TF card reader, a USB-C interface (PC), an antenna input, an RS232 port and an IR trigger input, allowing network integration, external control and direct content playback. eARC and CEC compatibility allows recovery of audio streams from a display while maintaining command synchronization.
Tonewinner AT-600
Tonewinner AT-600: Audio architecture and multichannel processing
The AT-600 relies on an ESS ES9081 DAC chip combined with a dual-core Analog Devices DSP, allowing processing of multichannel audio streams while maintaining high-resolution conversion accuracy. It supports Dolby Atmos, Dolby TrueHD as well as all backward-compatible Dolby formats, as well as DTS:X and DTS-HD Master Audio with their associated variants.
It allows configurations ranging from 2.0 up to 9.3.4, corresponding to 9 main channels, 3 subwoofers and 4 height channels. Analog outputs are available in 16-channel RCA (up to 9.3.4) and 14-channel balanced XLR (up to 7.1.6 or 9.1.4), allowing precise adaptation of connection type and number of subwoofers depending on the installation.
Tonewinner AT-600
Tonewinner AT-600: Acoustic correction and signal management
The integration of Dirac Live with Room Correction, Bass Control and ART allows acting on the frequency and time response of the system, while integrating advanced bass management with multiple subwoofers. A one-touch automatic calibration function allows adjustment of speaker distances, delays and sound levels, while equalization can be refined manually.
The dual-core DSP integrates a 5 to 11-band parametric equalizer per channel, allowing precise adjustment of each channel response depending on the configuration. An external measurement microphone can be added to perform the acoustic measurements required for calibration, allowing precise adaptation of correction to the listening room. Each input can retain its own parameters, including volume and equalization, allowing operation to be adapted according to the source used.
Tonewinner AT-600: Control and user interface
The AT-600 integrates an interface composed of two 2.8-inch screens allowing display of operating information, complemented by an OSD display in Chinese and English for on-screen navigation. Control can be performed via mobile application or remote control, allowing access to configuration and playback functions.
Audio playback is ensured via USB and TF card with file tree management and synchronized display of lists on screen and mobile application, allowing standalone use with FLAC, APE, WAV or MP3 formats. Adjustment of the audio delay up to 1000ms allows precise synchronization of sound with the image. An integrated wireless audio receiver allows reception of audio streams from a compatible source, expanding usage possibilities without wired connection.
Tonewinner AT-600: Measured performance and structure
The AT-600 features a signal-to-noise ratio greater than or equal to 110dB and a total harmonic distortion less than or equal to 0.004%, measured in pure analog mode, allowing maintenance of a low-noise signal with controlled distortion. The frequency response extends from 10Hz to 65kHz (+1/-3dB), while the output level reaches 4Vrms and channel separation ≥90dB.
The chassis is based on a metal structure, allowing limitation of interference and ensuring stable operation within a home theater integration.
Technical specifications
Product typeAudio / Video Processor
Home theater preamplifier
DAC chipESS ES9081
ChannelsTotal: 16 channels
Inputs6x HDMI
3x stereo RCA
2x Coaxial
2x Optical Toslink
1x Micro SD slot
1x USB-A (USB Host)
OutputsHDMI 2.1 (including 1 eARC and CEC)
RCA 7.3.6 / 9.3.4 channels
XLR 7.1.6 / 9.1.4 channels
Other connectors1x RS232
1x 5V trigger output
Supported audio formatsDolby Atmos
DTS/X
Dolby True HD
Dolby Digital Plus
DTS Master
DTS Hi-Res
DTS Upmix
DTS Neural X
Supported video formats / resolutions8K, YUV 4:4:4
Dolby Vision
HDR10 / HDR10+
HLG
Supported Dirac formatsDirac Live Room Correction
Dirac Live Bass Control
Dirac Live ART
Supported file formatsFLAC, APE WAV, MP3 etc
HDCP version2.3
eARC support
Automatic EQ calibration
Lip syncUp to 1000ms
Output level4Vrms ±1dB
Total harmonic distortion (THD)≤ 0.004%
Signal-to-noise ratio (SNR)≥ 110dB
Frequency response10Hz-65kHz
Channel separation≥ 90dB
Power supply voltage100-240VAC 50/60Hz
Max consumption30W
Dimensions431x304x80mm
Weight4.3kg
Characteristic1x Tonewinner AT-600
1x Remote control
1x Power cable
InputRJ45
InputMicro SD
InputHDMI
OutputHDMI eARC
OutputHDMI
Max sampling rateNC
Great AV-processor with Dirac for incredible value.
The Tonewinner AT-600 is a solidly built AV-processor with a ton of connectivity and a full set of dirac-features built in. My system: 7.2.4 with Tonewinner 7 Ch-Amp and NAD 4-Ch-Amp and B&W for speakers. First impressions: The case of the processor feels solid, all the connectors are gold-plated. The unit looks nice and clean with its big volume-dial in the middle and the two displays to the left and the right. The displays are big and can be set at different brightness-levels. The remote has a metal top face and is sturdy but it does not allow for the selection of all inputs. You have to use the smartphone app for that. Setup Before anything else, hook up the processor to the screen and set the speaker-configuration and the number of Subwoofers. You cannot configure this in the app. I last made a full Dirac setup with an older system more than 6 years ago and should have remembered how important setting all the speakers to a similar level is. So: do this first, if you don't want to have crazy bass-levels! For Dirac, you have to have a special microphone that is NOT included. The included micro only works with Tonewinner's own room-correction system! The Processor and the Computer to which the micro for Dircac is connected have to be in the same WIFI-Network. Sound and Picture The sound after the correct dirac-measurement was really great, clear and crisp. The spacial impression of the soundstage was both deep and wide. I lowered the bass-levels slightly, but this was the only adjustment I made. The picture quality is as expected, since I leave all the processing to the players and the projector and the processor has to just forward the signal. Operation The remote-control gives you direct access to three inputs you can define yourself. To select other inputs you have to use the input selection key that gives you the list of all inputs on screen you can select from. The Input selection through the app works better. Input switching is quick and reliable. The sound- and picture-formats are correctly identified and displayed on the left screen. The startup of the processor is sufficiently quick. There are two graphics on the screen when powering down. it would be nice if the user could customize them. Conclusion: The AT-600 is a great piece of AV-gear at a very good price considering the quality, connectivity and the fact that Dirac Live with Room Correction, Bass Control and Active Room Treatment are included. The build-quality seems to be very good, and the performance is more than satisfying. As for any niggles, they are minor and few: - DLNA-Compatibility would be nice, since the AT-600 has already the capability to play music-files from SD-Cards and USB-Drives and also has a permanent Network Connection. Allow for the reassigning of the symmetric outputs of the central Ceiling speakers as SW 2 and 3. This way a 7.2/3.4. system could be hooked up fully symmetrically. Recommendation: Go for it. If you have an extended AV-System and a tricky room that needs a good sound management, the AT-600 delivers at a price that is actually astounding.
This review has been posted for TONEWINNER AT-600 Audio-Video Processor / Home Theater Preamplifier 8K Dolby Atmos 16 Channels 9.3.4 / 7.3.6
The Tonewinner AT-600 is a 8K 16-channel home theater processor designed for processing immersive configurations up to 9.3.4, relying on a...
