MOONDROP MARIGOLD In-Ear Monitors IEM
The Moondrop Marigold are wired in-ear monitors integrating a 10mm dynamic transducer with a beryllium-plated dome, designed to deliver accurate reproduction on the go. They rely on an architecture combining an optimised magnetic circuit with integrated digital conversion via a built-in DAC, enabling processing of streams up to 32-bit / 384kHz while maintaining distortion as low as 0.05%, preserving signal intelligibility across the full frequency spectrum.
Reference : 22114
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 17-11-2026.
Moondrop Marigold Dynamic In-Ear Monitors IEM 32 Ohm 20Hz-20kHz
Moondrop Marigold : Front view
The Moondrop Marigold are wired in-ear monitors integrating a 10mm dynamic transducer with a beryllium-plated dome, designed to deliver accurate reproduction on the go. They rely on an architecture combining an optimised magnetic circuit with integrated digital conversion via a built-in DAC, enabling processing of streams up to 32bit 384kHz while maintaining distortion as low as 0.05%, preserving signal intelligibility across the full frequency spectrum.
Moondrop Marigold: Beryllium-Plated Dome Dynamic Transducer
The Moondrop Marigold rely on a 10mm dynamic transducer with a beryllium-plated dome, whose structure pairs a flexible composite suspension with an optimised internal magnetic circuit built around an N52 neodymium magnet. This architecture controls diaphragm movement while reducing parasitic deformation, resulting in fast transients, detailed reproduction and distortion held at 0.05%.
Moondrop Marigold : Driver
Moondrop Marigold: Integrated DAC
This approach is further extended by a DAC integrated directly into the cable, enabling decoding of audio streams up to 32bit 384kHz, allowing high-resolution sources from streaming platforms to be processed natively.
Moondrop Marigold : Supported sample rates
Moondrop Marigold : DSP
Moondrop Marigold: DSP
Beyond conversion, the second-generation DSP introduces a parametric equalisation interface accessible via the Moondrop Link application, allowing fine adjustment of the sound signature, profile sharing and access to community presets.
Moondrop Marigold: MEMS Microphone and NPU Voice Processing
The unit integrates a MEMS microphone paired with dedicated NPU processing for voice enhancement, isolating the voice from ambient noise while maintaining stable intelligibility, resulting in clear capture even in demanding acoustic environments.
Moondrop Marigold : NPU chip
Moondrop Marigold: VDSF Curve-Based Sound Tuning
Finally, the tuning is based on Moondrop's proprietary VDSF curve, delivering a balanced response across the full spectrum with articulate bass, intelligible midrange and detailed treble. This tonal coherence ensures consistent reproduction suited to a wide variety of musical content.
Moondrop Marigold : Frequency response curve
Product typeIn-ear monitors
Driver1x Ø10mm dynamic driver
Impedance32Ω
Frequency response20Hz-20kHz
Total harmonic distortion (THD)≤ 0.5%
Cable terminationUSB-C
ColorGrey
Package1x Moondrop Marigold
1x Carrying pouch
2x Pairs of ear tips
ColorGray
Impedance (Ω)32
WirelessNo
Headphone / Earphone connectorNon-detachable cable
Phone call featureYes
Noise reductionNo
MOONDROP MARIGOLD Dynamic In-Ear Monitors IEM 32 Ohm 20Hz-20kHz
The Moondrop Marigold are wired in-ear monitors integrating a 10mm dynamic transducer with a beryllium-plated dome, designed to deliver accurate...
