1MII RT5066PRO WiFi 2.4GHz Audio Transmitter Receiver
New
The 1Mii RT5066Pro is a kit consisting of a 2.4 GHz WiFi audio transmitter and receiver, designed to transmit sound from a television, computer, or AV amplifier to an active speaker, subwoofer, or sound bar. Its optical, coaxial, and 3.5 mm jack inputs and outputs make it easy to integrate into different systems, while its stated latency below 20 ms helps synchronize sound with picture.
Reference : 22575
69,90 €tax incl.
58,25 € tax excl.
1Mii RT5066PRO WiFi 2.4GHz Audio Transmitter Receiver
1MII RT5066PRO: Front view
The 1Mii RT5066Pro is a kit consisting of a WiFi audio transmitter and receiver 2.4GHz, designed to transmit sound from a television, computer, or AV amplifier to an active speaker, subwoofer, or sound bar. Its optical, coaxial, and 3.5mm jack inputs and outputs make it easy to integrate into different systems, while its stated latency below 20ms helps synchronize sound with picture.
Once powered, the transmitter and receiver turn on and pair automatically. The stated range reaches 100m outdoors and 30 to 50m indoors, depending on obstacles and interference. Its metal housing protects the devices in everyday use, but the RT5066Pro only transmits the audio signal: it does not act as an amplifier and cannot directly drive passive speakers.
Technical specifications
Product typeWiFi receiver / transmitter
Inputs1x RCA stereo
1x 3.5mm Jack
1x Toslink Optical
Outputs1x RCA stereo
1x 3.5mm Jack
1x Toslink Optical
Frequency band2.4GHz
Transmission range100m without obstacle
30-50m with obstacle
Supply voltage5V DC
Package1x 1Mii RT5066Pro Transmitter
1x 1Mii RT5066Pro Receiver
2x Toslink Optical to Toslink Optical cable
2x USB-A to USB-C cable
2x 3.5mm Jack to 3.5mm Jack cable
2x 3.5mm Jack to RCA stereo cable
2x Power adapter
InputJack 3.5mm
OutputCoaxial SPDIF
OutputJack 3.5mm
OutputBluetooth
OutputOptical Toslink
Transmission / Reception protocolWiFi
The 1Mii RT5066Pro is a kit consisting of a 2.4 GHz WiFi audio transmitter and receiver, designed to transmit sound from a television, computer, or...
