DAYTON AUDIO WAVE-LINK Wireless Transmitter Receiver 2.4GHz
The Dayton Audio Wave-Link is a versatile wireless transmitter and receiver duo, allowing you to wirelessly connect a subwoofer, satellite speakers, TV, amplifier... They eliminate the need for cables by bringing wireless connection to your audio system.
Reference : 16023
119,00 €tax incl.
99,17 € tax excl.
Grantie 5 ans
Dayton Audio Wave-Link Récepteur Émetteur Sans-Fil 2.4GHz
Installation of a wireless subwoofer
The Dayton Audio Wave-Link solves many wiring problems. Place your subwoofer, active speakers or amplifier in the most convenient locations without worrying about cables.
Integrated DAC
The Wave-Link has a built-in DAC, so you can connect it to any computer via USB and use the digital audio stream. A button on the transmitter works as a source selector, allowing you to simply choose between digital and analog input.
Stereo zone expansion
For users who want to add a stereo zone to an existing A/V installation, Wave-Link is the perfect tool. It allows you to add active or passive speakers with an amplifier outside of your main audio system to provide a wide area of sound. Connect Wave-Link to your PC, TV or media player to send a signal to any stereo system in your home
An adaptable system
The Wave-Link includes a wireless transmitter and receiver. It also comes with RCA to 3.5mm jack, RCA mono to 3.5mm jack and 3.5mm jack to 3.5mm jack cables. The system is designed to be scalable and adaptive as multiple receivers can be associated with a single transmitter to further expand your audio system.
Product typeWireless audio transmitter and receiver
Audio inputs (transmitter)1x Jack 3.5mm
1x USB-A
Audio output (receiver)1x Jack 3.5mm
RF frequency band2.403GHz to 2.479GHz
ModulationGFSK
Transmission distance20m max
Frequency response20Hz - 22kHz
Supported sampling ratesPCM up to 48kHz
Latency32ms
Supply voltage5VDC 500mA (Requires 2 US to FR adapters)
Dimensions152.4 x 38.1 x 19mm
InputJack 3.5mm
OutputJack 3.5mm
Transmission / Reception protocolWiFi
The Dayton Audio Wave-Link is a versatile wireless transmitter and receiver duo, allowing you to wirelessly connect a subwoofer, satellite...
