ALIENTEK BASE Bluetooth Receiver 4.1 aptX NFC DAC ES9023
The Alientek Base is a small, convenient and efficient Bluetooth receiver that will allow you to stream your music from your smartphone or any other Bluetooth device. Equipped with a DAC ES9023 it offers a beautiful sound reproduction.
Reference : 13684
44,90 €tax incl.
37,42 € tax excl.
Alientek Base
Bluetooth Receiver 4.1 Apt-X NFC DAC ES9023
Alientek Base Récepteur Bluetooth 4.1 Apt-X NFC DAC ES9023
The Alientek Base is a small, convenient and efficient Bluetooth receiver that will allow you to stream your music from your smartphone or any other Bluetooth device. With its integrated CSR8645 chip, it takes advantage of the 4.1 standard and aptX technology, which allow for higher signal transmission speed and stability and therefore better sound reproduction. In addition, this receiver includes an ESS ES9023 DAC ESS allowing to perform a quality digital / analog decoding, ensuring a nice transparency and dynamic audio. Bluetooth pairing can be done in the traditional way or in NFC by simply placing your smartphone (if it has NFC technology) on the Alientek Base. The latter is able to store up to 8 devices, which it will automatically detect as soon as their Bluetooth connectivity is activated again.
On the connector side, despite its small size, the Base offers a complete range of outputs. It includes an analog RCA Stereo output and another for headphones in 3.5mm Jack format, but also a S/PDIF Coaxial output and a Toslink Optical output. In addition, the receiver's Micro USB connector can be used to use the Base as a USB DAC.
Product typeBluetooth receiver
Bluetooth version4.1
Bluetooth chipCSR8645
Supported Bluetooth protocolsaptX, SBC
NFC PairingYes
DAC ChipESS ES9023
USB DAC ChipYes
InputsBluetooth
1x Micro USB (USB DAC)
Outputs1x Stereo RCA
1x Coaxial S/PDIF
1x Optical Toslink
1x Jack 3.5mm
Supported sampling rateBluetooth : Up to 16bit 44.1kHz
USB : Up to 48kHz
Frequency response18Hz - 20kHz
SNR≥ 105dB
Distortion0.01%
Bluetooth range20m
Min/Max Operating temperature-20°C / +85°C
Power supply5V 1A (sold separately)
Dimensions85 x 56 x 22mm
Housing materialPlastic
Package1x Alientek Base
1x Stereo RCA Cable 1.8m
1x USB-A to Micro USB cable
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9023
The Alientek Base is a small, convenient and efficient Bluetooth receiver that will allow you to stream your music from your smartphone or any...
