This product has been replaced by the new version, the DAYTON AUDIO WBA51.
Récepteur WiFi / Bluetooth avec Télécommande
The Dayton Audio WBA31 is an extremely easy to set up WiFi and Bluetooth multiroom receiver. The brand's Hi-Fly application makes it easy to control playback and playback from your smartphone or tablet. Featuring a 3.5mm jack connector and a Micro SD slot, the WBA31 can play your music from any connected device. The integration of the device into a previously unconnected audio system is easy thanks to the 3.5mm Jack and Optical outputs.
Multiroom
With the WBA31's multiroom function you can start playing your music directly in several rooms in your home for uninterrupted listening.
Multi channel
It is also possible to play your favorite songs on multiple devices independently or create groups of devices.
Multi User
Several users can share the broadcast in the house, each with the ability to control the audio source of the different devices.
Easy to use
The WBA31 is extremely simple. Simply connect your audio system to it and you have direct WiFi access.
Compact
With its small dimensions, this receiver can fit in the hand and can of course be integrated into all systems, even with limited space available.
Afordable
The Dayton Audio WBA31 is available at a low price and allows you to offer your system wireless reception without having to replace your current system.
Thanks to iEast application, the WBA31 is very easy to configure. Simply download this application from the Play Store for Android or the App Store for iOS. Once installed, simply launch the application that will guide you through a short series of simple steps to implement the receiver.
The iEast application turns your smartphone or tablet into a remote control to control all your connected Dayton Audio devices compatible with the application, and therefore the WBA31. You can start your music from a streaming application like Spotify or from your local network and of course enjoy the files stored on your phone. Hi-Fly allows you to play your music to your different WBA31s independently or create groups for a complete multiroom experience. In addition, your music continues to play even if your smartphone turns off or you receive a call. If you do not want to use your smartphone to control playback and broadcasting, a remote control is also provided.
Product type | WiFi / Bluetooth receiver |
Bluetooth | 4.0 |
WiFi | 802.11 b/g/n 2.4GHz 150mbps |
Supported protocols | DLNA Airplay |
Control app | Hi-Fly |
Inputs | Jack 3.5mm Micro SD |
Outputs | Optical Jack 3.5mm |
Power supply | 5V 2A via Micro USB (power adapter and cable included) - Requires a US to FR adapter |
Case material | ABS |
Color | Black |
Package | 1x WBA31 1x Power adapter 1x USB-A / Micro USB Cable 1x Jack 3.5mm Cable 1x Jack 3.5mm / Stereo RCA Cable |
Input | WiFi |
Input | Jack 3.5mm |
Input | Micro SD |
Input | Bluetooth |
Output | Jack 3.5mm |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Max sampling rate | NC |
Color | Black |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Web radios |
