TOPPING BC3 audio reveicer Bluetooth 5.0 aptX HD LDAC DAC ES9018Q2C 24Bit/96kHz Black
Battery-powered Bluetooth 5.0 Wireless High-Res receiver with integrated ES9018Q2C DAC. Offers line out, headphone out and even mini-toslink optical out. Compatible with Bluetooth 5.0 apt-X, apt-X LL, apt-X HD and LDAC.
4.3 / 5
Reference : 14727
69,00 €tax incl.
57,50 € tax excl.
TOPPING BC3
Bluetooth Receiver 5.0 aptX-HD / LDAC & DAC ES9018Q2C 24Bit-96kHz
The BC3 from Topping is a High-Res Bluetooth Wireless Receiver on battery with integrated DAC.
Thanks to its CSR8675 Bluetooth chip, the device supports the best Bluetooth audio standards available to date (BT 5.0 SBC / AAC / apt-X / aptX - LL / apt-X HD / LDAC) and can handle sampling frequencies up to  24bit - 96kHz.
Its wide range of connectors (Mini-Toslink, Line output, headphone output) makes it an ideal solution for easily connecting your bluetooth audio sources to your DACs, integrated amplifiers or headphones.
Its analog audio circuit also benefits from an ESS ES9018Q2C DAC offering excellent audio performance with THD+N <= 0.002% @ 1kHz on its headphone output and <0.001% on its line output for a noise level <2.3uVrms.
Bluetooth 5.0 apt-X HD & LDAC
The BCE3 receiver has a CSR8675 5.0 bluetooth chip on board that is compatible with the following protocols:
  • SBC / AAC
  • apt-X
  • aptX - Low Latency
  • apt-X HD
  • LDAC
The CSR8675 chip can receive digital audio streams with a sample rate of up to 96kHz-24bit for very high quality wireless reception.
The device is therefore Hi-Res Audio Wireless certified.
DAC ESS ES9018Q2C
The analog outputs (line output and headphone output) make the most of a decoding circuit based on an ES9018Q2C DAC chip.
This chip incorporates its own headphone amplification circuit capable of directly driving your headphones without going through an external amplifier. A simple and efficient way to use your wired headsets & IEM with a Bluetooth source while taking advantage of an excellent battery.
The line output is ideal for adding high quality Bluetooth connectivity to your integrated amplifiers or active speakers. It is also a very practical tool for adding bluetooth connectivity to a car's on-board sound system: once the line output of the BC3 is connected to the line input, each passenger can send their audio files independently.
Mini Toslink Optical Output
When not used as a line output, the 3.5mm output can also be used as a digital SPDIF output on mini-toslink port.
A mini-toslink to toslink adapter is provided to allow you to easily connect all kinds of digital audio devices.
This output allows you to connect your bluetooth sources to a DAC or DSP that does not have a native Bluetooth input in order to use it wirelessly and easily switch between audio sources.
With a suitable source, it is thus possible to send a 96kHz bluetooth LDAC signal to the BC3 and to recover an SPDIF signal without degrading this high sampling rate on the mini Toslink output.
800mAh Battery
Topping's BC3 nomadic Bluetooth 5.0 receiver has an 800mAh battery.
The latter follows a 3-hour charge cycle and can easily last 11 hours of once fully charged.
Charging is done with ease using the supplied USB-C cable.
TypeBluetooth Receiver
DAC
Bluetooth ChipCSR8675
Bluetooth Norm 5.0
Bluetooth ProtocolsSBC / AAC / apt-X / aptX - LL / apt-X HD / LDAC
DAC ChipES9018Q2C
InputsBluetooth
OutputsHeadphone Out - jack 3.5mm
Line Out / mini-toslink - jack 3.5mm
Output levelHeadphone Out : 2Vrms @0dBFs
Line Out: 2Vrms @0dBFs
THD+N@A-wtSortie casque : inférieur à 0.02% @1kHz
Sortie ligne: inférieur à 0.01% @1kHz
Noise@A-wt< 2.3Vrms
VolumeVolume control 32-steps
Receiving distance10m max
Battery800mAh
Batterie use@ Headphone Out 32Ω : ~12 hours
@ Mini-toslink Out: ~11 hours
@ Standby: ~25 days
Charge time : 3 hours
Dimensions60 x 60 x 17.5 mm
Weight82.5g
Package contents
Bluetooth receiver / DAC Topping BC3x1
Cable USB-A male to USB-C malex1
Adapter Mini-toslink male to toslink femalex1
OutputOptical Mini-Toslink
OutputJack 3.5mm
DAC / ADC ChipES9018Q2C
3 reviews
Questionning manufacturing quality
I had to return my BC3 after 5 months of operation as it suddently stopped functionning. Audiophonics provided me with a new product (thanks for a good ASS process) but one can wander if the manufacturing quality is at rigth level.
This review has been posted for TOPPING BC3 audio reveicer Bluetooth 5.0 aptX HD LDAC DAC ES9018Q2C 24Bit/96kHz Black
Topping BC3
Very good bluetooth receiver. Little but sturdy. I don't see a huge difference for wi-fi.
Topping E30
Excellent DAC, nice and sturdy. Good inputs and outputs. The sound is clear, clean and consistant. I'm very satisfied.
Battery-powered Bluetooth 5.0 Wireless High-Res receiver with integrated ES9018Q2C DAC. Offers line out, headphone out and even mini-toslink...
