Connector
Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
3 - 5
Mounting type
Insulation material
patrice f.
Soundcare standard
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
XLR Plugs
Discover our wide range of male and female XLR connectors, for the design of your XLR or AES/EBU audio cables.
