Connector
Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
3 - 5
Mounting type
Insulation material
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
XLR Plugs
Discover our wide range of male and female XLR connectors, for the design of your XLR or AES/EBU audio cables.
