NEUTRIK NC3FRX-B XLR Connector Female
The Neutrik NC3FRX-B is a 3-pin female XLR connector angled at 90°.
Reference : 21575
12,51 €tax incl.
10,42 € tax excl.
Shipping date: 17-11-2026.
Neutrik NC3FRX-B 3-Pin Female XLR Connector 90° Angled Gold-Plated Ø8mm
Photo of the NEUTRIK NC3FRX-B
The Neutrik NC3FRX-B is a 3-pin female XLR connector angled at 90°. The contacts of this connector are made of gold-plated copper alloy to ensure a high level of conductivity as well as resistance to oxidation and corrosion. It accepts cables with a minimum outer diameter of Ø3.5mm and a maximum of Ø8mm. Cable assembly is carried out by soldering with conductors up to a maximum cross-section of 2.5mm² (14AWG), while the overall connector assembly requires no screws for greater convenience. In addition to its practical assembly, 5 cable outlet positions are selectable.
Key features of the NEUTRIK NC3FRX-B:
  • Extra-slim right-angle connector
  • 5 selectable cable outlet positions
  • Male connector with improved locking recess without “window”, stronger housing for increased durability
  • Improved chuck-type strain relief providing higher pull-out force and enabling faster and easier assembly
  • Boot with polyurethane gland offering high protection against cable bending stress
  • Colored rings and boots available for coding or identification
Dimensions of the NEUTRIK NC3FRX-B
Technical Specifications
Product type90° angled female XLR connector
Capacitance between contacts≤ 4 pF
Contact resistance≤ 3mΩ
Dielectric strength1.5kVdc
Insulation resistance> 2GΩ (initial)
Rated current per contact16A
Rated voltage< 50V
Min/max cable outer diameterØ3.5 to Ø8mm
Max cable cross-section2.5mm² (14AWG)
Mounting typeSolder
Body materialDie-cast zinc
Body platingBlack chrome
Contact materialCopper alloy
Contact platingGold
Operating temperature-30 °C to +80 °C
Package contents1x Neutrik NC3FRX-B
Insulation materialPolyurethane (PUR)
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
NEUTRIK NC3FRX-B XLR Connector 3-Pin Female 90° Angled Gold Plated Ø8mm (Unit)
