Qualité Neutrik fabriqué pour Sommer afin d'utiliser leurs câbles de Diamètre 8 mm. Contacts plaqués Or.
3 Pins Male XLR Connector Gold Plated Ø8mm (Unit)
The Neutrik NC3MX is a 3-pole male XLR connector with zinc body and gold plated contacts. It is easy to assemble and consists of only 4 parts with a robust die-cast shell, a fiberglass-reinforced hard plastic insert and a chuck-type strain relief for secure clamping of all cables. The soft rubber end cap offers high protection against bending stress.
| Specifications | |
| Product type | Male XLR connector |
| Suitable cable diameter | Ø3.5 - 8mm |
| Max conductors section | 2.5mm² (14AWG) |
| Mounting type | To solder |
| Lifetime | > 1000 cycles |
| Tip material | Polyurethane |
| Contacts plating | Gold 2µm |
| Contacts material | Copper alloy |
| Insert material | Polyamide |
| Locking element / shell material | Zinc |
| Shell plating | Nickel |
| Temperature range | -30°C / +80°C |
| Standards | UL 94 V-0 IEC 61076-2-103 IP40 IEC 68-2-20 |
| Capacitance between contacts | ≤4pF |
| Contacts resistance | ≤3mΩ |
| Dielectric strength | 1.5kVdc |
| Insulation resistance | > 10GΩ |
| Rated current per contact | 16A |
| Rated voltage | < 50V |
| Insertion / withdrawal strength | ≤ 20N |
| General | |
| Total dimensions | Ø19.4 x 67mm |
| Insulation material | PE |
| Max cable diameter (mm) | 8.0 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts number | 3 |
| Connector | XLR |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
