LAIV XTR XLR to RCA Adapter (Pair)
New
The XTR is a high-quality XLR-to-RCA adapter designed to seamlessly convert a balanced XLR output to a single-ended RCA input.
Reference : 20873
64,00 €tax incl.
53,33 € tax excl.
Shipping date: 08-08-2025.
Photo of LAIV XTR
The LAiV XTR is a high-quality XLR-to-RCA adapter designed to seamlessly convert a balanced XLR output to a single-ended RCA input. Perfectly matched and tested for optimal compatibility with the Harmony µDAC, the XTR allows you to enjoy the µDAC’s performance even with amplifiers or systems that only support RCA inputs.
With its durable construction and clean signal path, the XTR adapter is the ideal bridge between balanced and single-ended systems.
Note: After converting to RCA Single-ended, the output voltage will be halved; please ensure compatibility with your amplifier's input sensitivity.
LAIV XTR
Product typeXLR to RCA adapter
PackageSold by pair
ConnecticMale & Female
ConnectorRCA
ConnectorXLR
Contacts Plating (Connector)N/A
