This versatile device (DAC, Headphone Amplifier and Preamplifier), has many inputs to be comfortable in all configurations.
Its Ultra Modern DAC allows you to manage 24-bit 192Khz sources directly via USB and SPDIF inputs.
The 100% discreet design of this amplifier is backed by a high power power supply and a relay volume controller.
The 24k Gold Plated RCAs and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Features:/ Strong>
| USB Interface | USB 32 (Via VT1731) |
| DAC | |
| THD | <0.001% |
| Signal / noise ratio | > 120dB |
| Output Level |
Output Power (Headphones). <Single-ended | 3300MW / 25 ohm |
| Output Power (Headphones). Balanced mode |
Gain | 12DB at H gain |
Output impedance | 2 ohms |
| himselfInput Capability |
| Frequency Response |
| USB compatibility | 44.1 to 192 kHz |
| Supported sampling rates | USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz Optical model: 44.1kHz, 48kHz, 88.2kHz,96kHz (176.4KHz and 192KHz available if the source support) |
| Consumption | 18W |
| Weight & Dimensions | 5KG 240 × 360 × 80mm |
| Accessories | AC power cord X1 USB cable X1 Mini remote controller X1 |
