Fonctionne comme prévu sur MacMini M1 sans rien installer. Il s'agit du modèle U2S 2019 (selon macOS).
USB to SPDIF Interface SA9023 24bit 96kHz Black
The Phiree U2S is a simple, efficient and compact USB to SPDIF and Optical. It is based on a Bravo SA9023 chip, supporting sampling rates up to 24bit 96kHz. It also allows AC3 and DTS ES signals to pass through (to another multi-channel decoder).
On this U2S there is therefore a Micro USB port at the input and a Coaxial connector and a Toslink Optics at the output. The interface allows Micro USB input for optical or coaxial output, and the USB cable is included. All this is integrated into a robust but compact aluminium housing with soft curves.
The Phiree U2S interface is OTG compatible and can therefore be used with smartphones that are also OTG compatible.
| Specifications | |
| Product type | USB Interface |
| Inputs | 1x Micro USB |
| Outputs | 1x Coaxial SPDIF 1x Optical Toslink |
| Sampling rate | Up to 24bit 96kHz |
| General | |
| Case material | Aluminium |
| Dimensions | 45 x 64 x 21mm |
| Weight | 50g |
| Color | Black |
| Package | 1x Phiree U2SX interface 1x USB-A to Micro USB Cable |
| Input | USB |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Max sampling rate | 96kHz |
| Color | Black |
| Interface chip | SA9023 |
Average votes 4.9 / 5 10 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Steve L.
Jean J.
Jean-François L.
Clément M.
