AUDIO-GD NFB-28 Balanced DAC / Headphone Amp / Preamp 32bit / 384kHz ES9018 TCXO
Audio-GD NFB-28 DAC/Ampli casque/Preamp 32bit/192KHz ES9018
By buying this product you get 94 loyalty points
Reference : 10439
949,00 €tax incl.
790,83 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
Its ultra-modern DAC allows you to manage 32bit 384kHz sources directly via Amanero (Asynchronous) USB interface and 32bit 192kHz via S / PDIF inputs.
This version incorporates the same new features as the NFB-1DAC namely:
  1. a better Saber implementation proposing a shorter signal path
  2. the possibility of selecting the hardware filters
  3. a DSD auto-detection (with switching noise-free switching).
  4. The disengagement of the preamplifier function (by a button on the back) allows a pure DAC use.
The 100% discrete and symmetrical design of this amplifier is backed by a high-power isolated power supply and a selection of high-end components (R-core transformers, DALE resistors, WIMA capacitors and 2 ultra low Jitter TCXO clocks.
Included Options:
  • Remote Control Aluminum
  • USB Interface Amanero
  • TCXO Clock (DAC)
Features:/ Strong>
  • 4 channels of digital input: coaxial (RCA) / optical / I2S on RJ45 / USB Asynchronous port
  • 2 groups of analog input: XLR / RCA
  • Output of the DAC: XLR * 2 / RCA * 2 / ACSS
  • Headphone Output: 4-pin XLR / Jack 6.35mm
  • Supplied with Aluminum remote control
USB Interface
Amanero
DAC
ESS Saber ES9018
THD
<0.0005% (0DBV output level)
Signal / noise ratio
> 120dB
Output Level
Headphone output: 19V RMS (balanced, max)
Preamp Variable output (balanced): 10V RMS (max)
Preamp Variable output (RCA): 5V RMS (max)
Fixed output (balanced): 5V RMS
Fixed output (RCA): 2.5V RMS
ACSS: 2MA + 2MA
Output Power (Headphones).
Single-ended
3300MW / 25 ohm
1650MW / 50 ohm
850 MW / 100 ohm
300 MW / 300 ohm
150MW / 600 ohm
Balanced mode
8000MW / 40 ohm
3500MW / 100 ohm
1200MW / 300 ohm
600MW / 600 ohm
Gain
12DBat H gain
0 DB at L gain
Output Impedance
2 ohms
Input sensitivity
0.5 Vp-p (75 ohms, Coaxial)
19 dBm (optical)
USB1.1, USB2.0 (Full Speed, Class 2)
0.7V to 5V RMS RMS (RCA)
0.7V to 10V RMS RMS (XLR)
Frequency Response
20Hz - 20KHz (<-0.05dB)
USB compatibility
44.1 to 192kHz
Supported sampling rates
Model USB / I2S: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz, 352.8, 384kHz
DSD 64/128
DXD
coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz
optical model: 44.1kHz, 48kHz, 88.2kHz, 96kHz
Consumption
25W
Weight & Dimensions
5KG
240 × 360 × 80mm
Accessories
AC
power cord x1
USB cable x1
Mini remote controller x1
Manufacturer:
https://www.audiophonics.fr/images2/8192/8192_audiogd_NFB-28_dac_thumbs.png
https://www.audiophonics.fr/images2/8192/8192_audiogd_NFB-28_dac_1.jpg
[Img-10173-left-thickbox_default]
[Img-14090-left-thickbox_default]
[Img-13362-left-thickbox_default]
[Img-13363-left-thickbox_default]
