With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. Each conductor is insulated with a PE jacket and the whole cable is triple shielded to protect the signal from possible interferences that could alter its quality. The connectors are gold plated to guarantee a great durability.
Thanks to this optimal design, the Pangea Premier SE MKII benefits from a high badnwidth of 48Gbps, supports high resolution video streams up to 8K 60Hz and 4K 120Hz as well as HDR technology.
| Specifications | |
| Product type | HDMI cable |
| Length | 2m |
| Connectors | 2* Male HDMI |
| Cable diameter | Ø9.5mm |
| Conductors material | Silver plated Cardas copper |
| Conductors section | 0.205mm² (24AWG) |
| Conductors insulation | PE |
| Shielding | Triple |
| Connectors contacts plating | Gold |
| Covering sheath | Braided nylon |
| Bandwidth | 48Gbps |
| Max supported resolutions | 8K 60Hz 4K 120Hz |
| HDR support | |
| General | |
| Color | Black and gray |
| Length (m) | 2.0 |
| Shielding | Yes |
| Section (mm²) | 0.205 |
| Connector | HDMI |
| Conductors Plating (Cable) | Silver |
