Jean Jacques R.
gaine large
j'ai du re-commander cette dimension pour mettre 2x cables de diam 7mm, je pensais que la gaine 7-14 pouvait faire 14mm de...
Jean-François G.
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a...
Raul P.
Good speaker
For that price speaker is relay good in full range. To get 80Hz like described you need a biger box.
List of products LHY Audio
LHY Audio designs and distributes high-performance and affordable DIY audio modules. The brand offers a wide range of products, from digital interfaces to linear power supplies, Bluetooth receivers and clocks.
  • Ref : 19056
    In Stock
    Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 9V.
    329,00 € 274,17 €Ex.
    In Stock
  • Ref : 15637
    This mains noise tester allows to measure the interference and therefore the noise on a power network and to compare filtered and unfiltered systems. It operates over a frequency range of 300kHz to 700kHz. Below or above these values, an LED lights up to indicate that the value is out of range.
    105,00 € 87,50 €Ex.
    In Stock
  • Ref : 19892
    In Stock
    The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six independent 10MHz 50/75Ω outputs on BNC connectors, including three sine-wave and three square-wave outputs. Based on a high-performance OCXO oscillator, it significantly improves...
    1 199,00 € 999,17 €Ex.
    In Stock
  • Ref : 19894
    In Stock
    In Stock
  • Ref : 18797
    In Stock
    These LHY Audio speaker protection modules contain a relay with a nominal voltage of 24V DC, a resistance of 1100 Ohms and a switching current of 16A.
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 19755
    In Stock
    This LHY Audio Receiver interface module converts an HDMI LVDS signal into an I2S signal. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 17565
    In Stock
    The single AOP LHY AUDIO is a discrete class A operational amplifier. Mounted on a stand, it offers quick assembly thanks to its DIP8 format. Even once installed, the AOP is easily changed. Designed for professional audio applications, it offers great performance. Indeed, it has greatly reduced noise, distortion and achieved an output current of 65mA.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 17570
    The double AOP LHY AUDIO is a discrete class A operational amplifier. Mounted on a stand, it offers quick assembly thanks to its DIP8 format. Even once installed, the AOP is easily changed. Designed for professional audio applications, it offers great performance. Indeed, it has greatly reduced noise, distortion and achieved an output current of 65mA.
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 19756
    This LHY Audio Send interface module converts an I2S signal to HDMI LVDS. It accepts PCM and DSD signals, enabling users to enjoy high-resolution files.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 19168
    LHY Audio offers us their SW-10 network switch. This switch features 8 RJ45 Ethernet ports, 2 SFP fiber optic ports and an input and output connected to the 10mHz OCXO clock. All of this is housed in an elegant anodized aluminum case, machined from solid, and designed to separate AC power processing, DC power processing and audio signal processing.
    1 890,00 € 1 575,00 €Ex.
    In Stock
  • Ref : 19170
    In Stock
  • Ref : 19490
    Reduced price!
    In Stock
    With the SW-6 SPF, LHY Audio offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre optic SFP port and a BNC input connected to the 10mHz OCXO clock. All this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current...
    816,05 € 680,04 €Ex.
    859,00 € In Stock
  • Ref : 19491
    In Stock
    859,00 € 715,83 €Ex.
    In Stock
  • Ref : 17281
    This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal. The module can be AC or DC powered and is capable of delivering 5V and/or +/-12V (adjustable over a range of 1.2V to 20V). It can be used to provide three positive outputs or one...
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 17279
    This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal. The module can be AC or DC powered and is capable of delivering 5V and/or +/-5V (adjustable over a range of 1.2V to 20V). It can be used to provide three positive outputs or one...
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 18475
    This LHY Audio UBT-1 digital interface lets you transmit a high-quality digital audio signal via your computer, tablet or smartphone to other digital audio devices. The UBT-1 digital interface features a USB-B connector input, a Bluetooth 5.1 receiver chip and several outputs: AES/EBU, SPDIF Coaxial, Optical Toslink, and HDMI-I2S.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 18765
    With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect transmission of your sound signal via USB connectors. The LHY Audio UIP works plug and play thanks to a USB-B input and a USB-A output supporting the USB 2.0 protocol. USB...
    549,00 € 457,50 €Ex.
    In Stock
  • Ref : 19741
    The LHY FMC galvanic network isolator optimizes your audio system's Ethernet LAN connection. It converts the network signal into an optical signal via its SFP port, and outputs it via its galvanically isolated RJ45 port.
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 19746
    In Stock
  • Ref : 21576
    The LHY-Audio linear power supply is a low-noise power supply based on the use of a high quality custom toroidal transformer, high-performance LT3086 regulators, high-current, low-resistance Schottky rectifiers, and Vishay BC electrolytic capacitors, all mounted on a four-layer PCB with gold-plated copper circuits.
    In Stock
  • Ref : 21194
    The SW-10 PRO is a high-end network switch from LHY Audio featuring six RJ45 ports, two SPF ports, and two BNC outputs directly connected to two SC-CUT OCXO clocks. All of this is housed in an elegant aluminium housing where each operating stage is physically isolated from the others, ensuring complete lack of crosstalk interference.
    2 799,00 € 2 332,50 €Ex.
    In Stock
  • Ref : 21198
    2 749,00 € 2 290,83 €Ex.
    In Stock
