The Ian Canada 92A is a dual-mono DAC kit based on two ES9038Q2M chips. Designed for synchronised digital-to-analogue conversion via an external clock in SYNC mode, it utilises the FifoPi Q7III module, which buffers and reclocks the I2S stream, thereby stabilising jitter prior to conversion, whilst the dual-mono architecture isolates the two channels to improve separation and reproduction accuracy. This foundation is complemented by a feedback-free OPA861 balanced I/V stage, which converts the DAC’s output current to voltage whilst maintaining a linear response.
This approach is extended with the ReceiverPi DDC II, which consolidates digital inputs into a coherent I2S bus, whilst the distribution of the MCLK from the FifoPi to the DAC ensures direct synchronisation with the reference clock. The StationPi SMT acts here as an integration platform, organising the connections between modules and facilitating the addition of a Raspberry Pi or USB interface. Finally, the integration of the MonitorPi Pro ensures system control and monitoring, thereby enabling centralised management.
| Specifications | |
| Product type | DAC module kit |
| Inputs | 1x I2S via HDMI 1x USB 1x Coaxial SPDIF 1x Optical Toslink |
| Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
| DAC chips | 2x ES9038Q2M |
| Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD1024 |
| General | |
| Package | 1x Ian Canada 1D FifoPi Q7 III 1x Ian Canada 4B ES9038Q2M Dual Mono II DAC 1x Ian Canada 6B OPA861 Zero feedback balanced I/V 1x Ian Canada 19D ReceiverPi DDC II 1x Ian Canada 35C StationPi SMT 1x Ian Canada 49B MonitorPi Pro 1x Ian Canada 50A GPIO extension KIT4 1x Ian Canada 50B GPIO spacer 4x Spacer 13/1.2 mm |
