IAN CANADA 93D Streamer Module Kit
The Ian Canada 93D is a DIY network player kit based on a reclocked FIFO architecture, designed to ensure I2S/DSD signal conversion and regeneration independent of any host platform. It utilises the FifoPi Q7III module for low-jitter buffering and reclocking, whilst the PurePi II supercapacitor power supply stabilises critical rails to reduce noise fluctuations and transient disturbances. This combination enables the reconstruction of a temporally coherent digital stream, directly influencing the accuracy of downstream conversion via the I2S output to HDMI.
By buying this product you get 79 loyalty points
Reference : 21612
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 12-11-2026.
Ian Canada 93D Streamer Module Kit with FIFO I2S Reclocker
IAN CANADA 93D : Front view
The Ian Canada 93D is a DIY streamer kit based on a reclocked FIFO architecture, designed to ensure I2S/DSD signal conversion and regeneration independent of any host platform. It utilises the FifoPi Q7III module for low-jitter buffering and reclocking, whilst the PurePi II supercapacitor power supply stabilises critical rails to reduce noise fluctuations and transient disturbances. This combination enables the reconstruction of a temporally coherent digital stream, directly influencing the accuracy of downstream conversion via the I2S output to HDMI.
Beyond this technical foundation, the integration of the ReceiverPi DDC II extends the management of digital inputs by converting them to a unified I2S bus, whilst the HdmiPiPro II module ensures differential signal transmission, thereby minimising interference and parasitic ground loops. This approach is extended with the MonitorPi Pro, which monitors clock and power supply parameters whilst allowing direct control of the system, thereby enabling the behaviour of the digital stream to be adjusted according to the chosen configuration. For those wishing to integrate a dedicated USB interface, compatibility with Amanero modules broadens the range of implementation scenarios.
The spikes are sold separately.
Product typeStreamer module kit
Inputs1x I2S via HDMI
1x USB
1x Coaxial
1x Optical Toslink
OutputI2S LVDS via HDMI
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD1024
Package1x Ian Canada 1D FifoPi Q7 III
1x Ian Canada 48B PurePi II
1x Ian Canada 49B MonitorPi Pro
1x Ian Canada 19D ReceiverPi DDC II
1x Ian Canada 17B HdmiPi Pro II
(Spikes sold separately)
IAN CANADA 93D Streamer Module Kit with FIFO I2S Reclocker
The Ian Canada 93D is a DIY network player kit based on a reclocked FIFO architecture, designed to ensure I2S/DSD signal conversion and...
