Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
This 15cm PH 2.0mm cable consists of 10 wires, has a 10 pole female PH 2.0mm connector on the one hand, and bare wires on the other. This type of cable can be very useful in DIY assemblies, to connect different modules with PH 2.0mm plugs.
This PH 2.0mm male/male ribbon cable will allow you to make quick connections between two PH 2.0mm female connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
This high-quality cable features a 2.0mm 4-pin PH connector (2 rows) and 4 stripped wires (2x red, 2x black). It will enable you to make assemblies more easily on your PCBs also fitted with PH connectors.
The PM8000 is a quality 48V USB phantom power supply, designed to power a condenser microphone or a measuring microphone. The power supply incorporates a filter circuit and AC signal isolation to minimize interference.
This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF each and two WIMA 1µF coupling capacitors, for a clean signal and a rich and precise sound reproduction.
This stand is ideal for stabilizing a device while disconnecting it from an assembly to limit vibrations. It is made of CNC machined anodized aluminum and a rubber ring prevents the device from slipping, while damping vibrations.
This straight male bar JTAG connector has 10 pins (2x5 pins) on deux row. The pines are 2.54mm apart. This type of connector will allow you to quickly and easily mount to PCBs.
This straight female / male bar connector has 10 pins (10 pins) on one row. The pines are 2mm apart. This type of connector will allow you to quickly and easily mount to PCBs.
This pair of connectors is designed around the brand's know-how. With two pins, they are suitable for the design of cables compatible with some Sennheiser headphones, such as the HD800, HD800S, HD820 as well as the ENIGMAscoutics Dharma D1000 headphones. The design of these connectors guarantees a flawless sound quality.
This ABS plastic case allows to protect efficiently a Raspberry Pi 4, while leaving all its connectors accessible. The GPIO is covered by a cover, which can be removed with a simple cutter if needed. A small fan (not supplied) can be added to the cover to dissipate the heat of the Raspberry Pi.
