Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
This interconnection cable is composed on the one hand of an XHP connector, on the other hand of a bare wire. Ideal for designing your DIY projects and internal wiring.
This cable is composed of a 2.54mm female XH format connector on the one hand and a bare soldered wire on the other hand. This interconnect cable is ideal for internal wiring of your DIY projects, for quick and easy XHP plug connections.
This cable is composed of a 2.54mm male XH format connector on the one hand and a bare soldered wire on the other hand. This interconnect cable is ideal for internal wiring of your DIY projects, for quick and easy XHP plug connections.
These cables have an XHP format connector on the one hand and a bare soldered wire on the other end. These offer a Silicone coating, offering insulation and flexibility.
This good quality shielded cable has a 2.54mm 3 pole XH connector and 3 bare wires (red, white, black). It will allow you to carry out simpler assemblies on your PCBs also having connectors XH. In addition, the cable shielding reduces interference and noise generated by the cable.
This 10cm cable is composed of 2 wires and has on the one hand a 2 pole female XH 2.54mm connector and on the other hand a 2 pole female PH 2.0mm connector. This type of cable can be very useful in DIY assemblies, to connect different modules with XH and PH plugs.
This 10cm cable is composed of 3 wires and has on the one hand a 3 pole female XH 2.54mm connector and on the other hand a 3 pole female PH 2.0mm connector. This type of cable can be very useful in DIY assemblies, to connect different modules with XH and PH plugs.
This 10cm cable is composed of 4 wires and has on the one hand a 4 pole female XH connector and on the other hand a 4 pole female PH 2.0mm connector. This type of cable can be very useful in DIY assemblies, to connect different modules with XH and PH plugs.
This 2.54mm XH male connector with 2 channels (2 pins) will allow you to make simpler and faster connections when mounting DIY. In addition, its pines are gold plated to ensure good conductivity and resistance to oxidation.
This 2.54mm XH male connector with 3 channels (3 pins) will allow you to make simpler and faster connections when mounting DIY. In addition, its pines are gold plated to ensure good conductivity and resistance to oxidation.
This 2.54mm XH male connector with 4 channels (4 pins) will allow you to make simpler and faster connections when mounting DIY. In addition, its pines are gold plated to ensure good conductivity and resistance to oxidation.
This 2.54mm XH male connector with 5 channels (5 pins) will allow you to make simpler and faster connections when mounting DIY. In addition, its pines are gold plated to ensure good conductivity and resistance to oxidation.
This 2.54mm XH male connector with 6 channels (6 pins) will allow you to make simpler and faster connections when mounting DIY. In addition, its pines are gold plated to ensure good conductivity and resistance to oxidation.
This XH 2.54mm female/female ribbon cable will allow you to make quick connections between two XH 2.54mm female connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
This XH 2.54mm female/female ribbon cable will allow you to make quick connections between two XH 2.54mm male connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
