IBASSO AMP17 Amplifier Module for DAP DX340
The iBasso AMP17 is an amplifier module specially designed to accompany the brand's DX340 DAP, providing it with GaNFET transistor amplification for an impressive total power output of 1900mW+1900mW at 32Ω.
Reference : 21396
249,00 €tax incl.
207,50 € tax excl.
iBasso AMP17 GaNFET Amplifier Module for DAP DX340 Silver
iBasso AMP17 : Vue de face
iBasso AMP17: GaNFET transistors
The AMP17 amplifier module uses a topology based on GaNFET transistors, whose internal resistance is significantly lower than that of traditional MOSFETs, allowing higher currents to pass without premature compression. This feature, enhanced by the module's low-impedance architecture, translates into the ability to maintain stable and extended output dynamics, even with very low-impedance headphones that require instantaneous and demanding current. Beyond raw power, this approach ensures more responsive reproduction, with bass response and transient articulation preserved even at sustained volume levels.
iBasso AMP17 : Diagram of internal operation
This electrical efficiency is accompanied by a switching frequency significantly higher than that of conventional MOSFET architectures, allowing switching residues to be pushed well beyond the useful audio band. By mechanically reducing interference related to signal oscillation, the module limits analogue plane pollution, contributing to a more stable sound stage and clearer micro-dynamics. This control of background noise directly benefits extended listening sessions, particularly with transducers that are sensitive to phase variations and interstitial silence.
iBasso AMP17: Output power of 1900mW + 1900mW
For those seeking tangible power reserves, the AMP17 accepts a 12V power supply, which is necessary to activate Super Gain mode, in which it is capable of delivering up to 1900mW per channel into 32Ω. This high output capacity is not exploited as a mere numerical demonstration, but as a control lever, allowing for a comfortable dynamic range and clipping-free reproduction on complex or inefficient loads.
This hardware versatility is reflected in its compatibility with the DX300, DX320 and DX340 players, allowing direct integration into the iBasso ecosystem. However, this approach only reaches its full potential with the DX340, the only model capable of providing the 12V power supply required to fully utilise the module, making it the benchmark platform for taking advantage of all the dynamic and energetic capabilities of the AMP17 in real listening conditions.
iBasso AMP17 : Output power of 1900mW + 1900mW
Product typeAmplifier module for DAP
Outputs1x Amplified output 4.4mm jack
1x 4.4mm jack output
CompatibilityDX300
DX320
DX340
Total harmonic distortion more noise (THD+N)-116dB (No load)
-110dB (600Ω load)
Dynamic range120dB
Signal-to-noise ratio (SNR)122dB
Crosstalk-117dB
Frequency response10Hz-40kHz (±0.5dB)
Output impedance1.1Ω
Output powerBattery power supply : 1030mW + 1030mW @32Ω
12V power supply : 1900mW + 1900mW @32Ω
Line output 4.4mm jack
Plage dynamique126dB
Rapport signal sur bruit (SNR)123dB
Diaphonie-97dB
Output levelLow gain : 1.6Vrms
Medium gain : 2.6Vrms
High gain : 3Vrms
ColorSilver
Package1x iBasso AMP17
1x Screwdriver
Fixing screw
InputNC
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rateNC
QUEL PLAISIR !!!
merci audiophonics pour la livraison ultra rapide, je savais pour la non disponibilité du produit, et reçu 20 jours avant l'estimation prévu... l'amp 17 dés la première écoute est juste énorme alors qu'il n'est pas rodé, un peu moins dynamique que l'amp 15, lui rodé, mais plus de détails, scène sonore plus ample, j'ai enlevé le casque plusieurs fois, pensant que certain son venait de l'extérieur, encore une fois il n'es pas rodé, j'ai toujours tendance à coupler mon dap avec un dac, là, limite pas besoin, tout est la... je possède l'ibasso DX 100, le premier lecteur haut de gamme de la marque, ASTELL & KERN AK 300, HIBY RS2, on va dire que l'ibasso dx 340 possède toute les qualités de ces 3 lecteurs sans les défauts... merci encore à audiophonics qui est le seul distributeur de l'amp 17 en France si je ne me trompe pas....
This review has been posted for IBASSO AMP17 GaNFET Amplifier Module for DAP DX340 Silver
The iBasso AMP17 is an amplifier module specially designed to accompany the brand's DX340 DAP, providing it with GaNFET transistor...
