IBASSO AMP19 Amplifier Module for DX340
New
The iBasso AMP19 is an amplifier module designed for the brand's DX340 portable audio player. It combines a Nutube 6P1 vacuum triode and a discrete Class A amplification stage on a single board, offering two distinct sound signatures. In Tube mode, the Nutube acts as a preamplifier and adds more harmonic richness, with a warmer presentation and vocals with smoother textures. Super Class A mode relies on 20 dual transistors and can deliver up to 2 A, favoring a large current reserve, fast transients and a denser presentation.
Reference : 22639
299,00 €tax incl.
249,17 € tax excl.
iBasso AMP19 Amplifier Module for DX340
IBASSO AMP19 : Front view
The AMP19 from iBasso is an amplifier module designed for the brand's DX340 portable audio player. It combines a Nutube 6P1 vacuum triode and a discrete Class A amplification stage on a single board, offering two distinct sound signatures. In Tube mode, the Nutube acts as a preamplifier and adds more harmonic richness, with a warmer presentation and vocals with smoother textures. Super Class A mode relies on 20 dual transistors and can deliver up to 2A, favoring a large current reserve, fast transients and a denser presentation.
To extend its driving capability, the AMP19 can be powered by an external 12V source: this power supply raises the output stage voltage from ±6.5V to ±12V and allows up to 2150mW + 2150mW into 32Ω in Super Class A mode. The board thus retains a portable format while being able to drive demanding headphones. In Tube mode, the JRC analog volume control offers 100 adjustment steps and reduces noise at low volume, while the suspended mounting on PORON material limits vibrations transmitted to the tubes.
Technical specifications
Product typeAmplifier module for DAP
Outputs1x 4.4mm Jack
1x 3.5mm Jack
CompatibilityDX340
Amplified Outputs Super Class A Mode
Output level3.5mm Jack: 4.15V (Super gain)
3.5mm Jack: 2.92V (High gain)
3.5mm Jack: 1.89V (Mid gain)
3.5mm Jack: 0.89V (Low Gain)
4.4mm Jack: 8.3V (Super gain)
4.4mm Jack: 5.8V (High gain)
4.4mm Jack: 3.8V (Mid gain)
4.4mm Jack: 1.8V (Low Gain)
Output power3.5mm Jack: 500mW + 500mW @ 32Ω (12V DC)
3.5mm Jack: 260mW + 260mW @ 32Ω (Battery)
4.4mm Jack: 2150mW + 2150mW @ 32Ω (12V DC)
4.4mm Jack: 1000mW + 1000mW @ 32Ω (Battery)
Total harmonic distortion more noise (THD+N)3.5mm Jack: -105dB
4.4mm Jack: -109dB
Signal-to-noise ratio (SNR)3.5mm Jack: 110dB
4.4mm Jack: 121dB
Dynamic range3.5mm Jack: 110dB
4.4mm Jack: 121dB
Crosstalk-114dB
Frequency response10Hz-40kHz (±1dB)
Output impedance3.5mm Jack: 0.7Ω
4.4mm Jack: 1.4Ω
Amplified Outputs Tube Mode
Output level3.5mm Jack: 3.7V (Super gain)
3.5mm Jack: 2.3V (High gain)
3.5mm Jack: 1.49V (Mid gain)
3.5mm Jack: 0.79V (Low Gain)
4.4mm Jack: 7.7V (Super gain)
4.4mm Jack: 4.53V (High gain)
4.4mm Jack: 2.92V (Mid gain)
4.4mm Jack: 1.55V (Low Gain)
Output power3.5mm Jack: 428mW + 428mW @ 32Ω (12V DC)
3.5mm Jack: 165mW + 165mW @ 32Ω (Battery)
4.4mm Jack: 1850mW + 1850mW @ 32Ω (12V DC)
4.4mm Jack: 590mW + 590mW @ 32Ω (Battery)
4.4mm Jack: 1.4Ω
ColorSilver
Package1x iBasso AMP19
1x Screwdriver
Mounting screws
InputNC
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rateNC
The iBasso AMP19 is an amplifier module designed for the brand's DX340 portable audio player. It combines a Nutube 6P1 vacuum triode and a...
